audio tracks synced to picture when Setting Chunk Start Time
Posted: Thu Mar 24, 2016 4:39 pm
by hamburski
So I've got this three-minute video and the v/o and sfx are provided as separate stems. I'm wanting to reset the chunk start time so I can work on a cue in the middle of the video. Is there a way to keep audio locked to picture when I do so? Right now, when I reset the start time, the audio stays where it is, and I don't want to re-sync three stems manually to picture...
Re: audio tracks synced to picture when Setting Chunk Start
Posted: Fri Mar 25, 2016 2:23 pm
by frankf
Make a Time Line Selection of the cue, include all tracks including conductor track then use Copy Selection to new sequence command. The new sequence will have the correct start time and the movie start does not change.
Posted: Mon Mar 28, 2016 11:00 am
by hamburski
Thanks, Frank, those were a couple of new moves to me and got me most of the way there. The thing I'm still trying to sort out is: I'm of course using different tempos for different cues, and so even once I relocate a given section of picture to a new location, I still don't necessarily have my downbeat exactly where I want it. With picture and audio bound together, I would just do Set Chunk Start Time to get downbeat right on my starting frame, but having the audio stemmed out like this is the problem. Is there a way you'd suggest doing the initial Timeline Selection to solve this snag?
Posted: Mon Mar 28, 2016 8:28 pm
by frankf
When I spot the cues in the spotting sequence, I use locked markers and the tempo doesn't matter. I set the tempo for each cue, and time signature, after I break it out to its own sequence using the method I described.
Frank Ferrucci
