UVI workstation question - save preset changes?
musicman691
Post by musicman691 »
Didn't want to pile on on the Digital Synsations download threads so am starting a new thread. Took a while to do the d/l (about 11 hours using folx). Got that and the free Workstation d/l. Installed both no problem after I read the pdf on how to do things :oops:
Has some interesting preset sounds. A lot of what I like to do is to start with a preset and modify it to suit me. I'm talking about single mode here, not multi mode. And therein lies the rub - if I make a change and I like it there's no way that I can find to save said change that I can see; looked all over the manual. The only thing I can find is how to save a multi but not a single. Is it just not possible to save a single patch for an instrument? If there is can someone clue me in on how to do the deed?
Thanks.
Re: UVI workstation question - save preset changes?
Mach Five does it but I don't think you can save individual part patches with UVI player. You can save UVI settings in the DP Channel Strip Insert Settings, but that doesn't help over just saving the Multi.
Looks like it's being prevented. In the Effects Window, there is a "save preset" option active, but it does nothing.
musicman691
bayswater wrote:Mach Five does it but I don't think you can save individual part patches with UVI player. You can save UVI settings in the DP Channel Strip Insert Settings, but that doesn't help over just saving the Multi.
I figured M53 would allow individual part patches as I would imagine Falcon would as well but I'm not flush enough with cash to buy either at the moment. While it's neat one can save settings from within a daw those settings are only usable in that daw and aren't available in another; I use both DP and PT and would like to be able to see the same changed patch in the other.
Oh well - I guess for free one can't complain too much.
The other workarounds: save all the possible combinations of parts you might use as multis, or save multis with one part only and use multiple instances of the player.
Or, pick out a few of the UVI sounds you like and use something like Autosampler (or whatever it's called now in Mainstage) to get what you want in a form that can be brought into Kontakt, assuming you have that.
musicman691
bayswater wrote:The other workarounds: save all the possible combinations of parts you might use as multis, or save multis with one part only and use multiple instances of the player.
Thanks for the tip. Don't have Mainstage; I do have the full Kontakt though so I've got that much.
emulatorloo
Post by emulatorloo »
Mainstage is pretty cheap ($29.95) and is a good tool if you want to autosample a synth at multiple velocities. Then you can take the samples into Kontact.
Also has all the logic synths, including Alchemy. Those are fun to play.
emulatorloo wrote:Mainstage is pretty cheap ($29.95)...
Now THAT is a no brainer! Nice to see you back here, man.
2013 Mac Pro 32GB RAM
