unwanted MIDI input
Joey010
unwanted MIDI input
Post by Joey010 »
Hello!
I'm going crazy..
When i insert an instance of ''Fxpansions Geist'' drum plugin without a MIDI channel connected to it it will send MIDI output to all instruments in the song..
And when i add a MIDI channel for Geist it totally flips out when you press a drum pad it repeats the sample like 50 times very fast..BBBBBRRRRRRRRRrrrrrrrrrr
is there a known conflict between Fxpansion plugins? It works fine in other daw's installed on the same computer.
(Windows 10)
Re: unwanted MIDI input
I don't know the plugin, but fast repeats can be an indication that there is a MIDI feedback loop somewhere: MIDI coming from some source is going back to the source and being sent again.
