How to copy audio volume automation & paste as send volume?
FMiguelez
Post by FMiguelez »
Hello.
I have automated the volume to tame "esses" and Ts and Cs from a singer. However, there´s a section where I´m using a sort of slap delay, but some consonants sound terrible dancing around in the stereo field.
I have the volume automation drawn for these sounds already. Thought it would be nice not do do them again for the sends. How can I paste them (convert them with the same shape) to send volume?
reedster
Re: How to copy audio volume automation & paste as send volu
Post by reedster »
Region / Reassign Continuous Data / check copy and set From / To
MacBook Pro 9,1 15" 16gb | 10.12.4 | DP 9.13 | xAir | NI | WIVI | Garritan | Izotope | Bidule
Select your volumes (double click on one point and they all become selected).
Under the REGION menu, select REASSIGN CONTINUOUS DATA and choose COPY at the top (unless you just want tome it).
Bottom pane, select EFFECT AUTOMATION.
From that drop down select: INTERNAL SEND LEVEL.
Does that do it?
FMiguelez
Post by FMiguelez »
reedster wrote:Region / Reassign Continuous Data / check copy and set From / To
Yay! :D
MIDI Life Crisis wrote:Select your volumes (double click on one point and they all become selected).
Does that do it?
Yes it does!
Perfect! Works like a charm.
I think I had used that command for MIDI years ago... I didn't know DP was so powerful as to do these changes to audio automation as well.
Thanks. You guys rock. As does DP!
:unicorn:
solex
Post by solex »
I stumbled across a problem with copying automation. Didn't work with the view filter and then just mark - copy - paste. So I tried the above described method and stumbled upon this error (see screenshot-link), which I do not understand, any help appreciated.
http://www.limsound.com/work/whatnow.png
Drumwizard
Post by Drumwizard »
solex, it works as expected for me in DP10.1.
solex
Post by solex »
sorry, I forgot, I'm on DP 9.52 with Mojave
waynepeet
Re: How to copy audio volume automation & paste as send volume?
Post by waynepeet »
Just tried this on DP 11.22 / OS 13.4 & it didn't work.
Trying to copy Send 2 automation into Send 1. Had "Copy" selected, and source & destination correct.
All that happened was the Send 2 automation got erased.
Wayne Peet / Killzone Music / Los Angeles
MacPro 5,1 2010 upgraded motherboard 12 core 3.46 GHz, 64 GB RAM, NVIDIA GeForce GTX 760, MOTU 424 PCIe, UAD PCI, SSD drives, OS 10.12.x & 10.14.x
