Transitioning to a Mac Pro Trash Can (one perspective)
Re: It's done. :)
Trying a USB 3 dock now. Hope it freakin' stays connected. The CalDigit 800 FW stuff never misbehaved before so I'm thinking it has something to do with the TB to FW 800 cable or the enclosure itself. The USB 3 dock seems to be going quite fast.
Re: It's done. :)
it shouldn't give you grief but, if it does, open Console to see if it is hanging on an obsolete file.
Migration Assistant is different than Restore From Backup or another volume.
Re: It's done. :)
The USB3 dock did the trick. All my authorizations are now redone (only a handful needed attention) and the machine is back up exactly as before. Well, almost. Quickeys is a little wonky and unreliable. May be time to ditch it for that other app?
To answer your earlier question more fully Mike, the machine is a 3.7 GHz Quad-Core Intel Xeon E5 with a AMD FirePro D300 2048 MB and 32GB of RAM. I suspect the bugaboo will be hard drives on the FW buss. I'm really used to the internals but eventually they'll all be SSDs and I'll be farming (I think) from the MP 8 core. Maybe not. I still need to play with buffer sizes, etc.
But other than that techie stuff, the machine is truly amazingly fast. Practically a no wait state for many things. I'm gonna get spoiled fast!
Re: It's done. :)
Wow. 27 years of QK, most likely coming to an end now. I wish that someone else would buy it and get it running again. I haven't tried "that other app," but it's hard to imagine anything being put together as nicely as QK.MIDI Life Crisis wrote:Quickeys is a little wonky and unreliable. May be time to ditch it for that other app?
Re: It's done. :)
Oh yea, that'll get old in a hurry.I suspect the bugaboo will be hard drives on the FW buss...
Spinners on the usb 3 or TB buss are limited by the platter speed. This is a bit faster than they are on the old MP 3G internal buss. It's about 5-8x faster than FW800, however, depending on the actual performance of the drive.
Since you now have a usb 3 dock, put the drive you will access the most in it for now. Replacing it with an SSD will increase the speed.
Yes, you will get spoiled quickly. The process has begun.
Re: It's done. :)
And oddly enough, the Google.com site STILL won't load. Ha ha ha! That elfin' crazy. San Rafael gig coming Jan 17-18. 18th should be good and I get to use my own piano.
- BKK-OZ
Re: It's done. :)
The R4 is plenty snappy for me, it has never proven itself to be a bottle neck.MIDI Life Crisis wrote:I suspect the bugaboo will be hard drives on the FW buss.
Cheers,
BK
- M Kaku
BK
- M Kaku
Re: It's done. :)
Haha. That "other app" is Keyboard Maestro and I've been using it for years successfully with DP and Mac Os through Mavericks. I've not upgraded to Y but compatibility reports are good. Developer updates and improves constantly.MIDI Life Crisis wrote:May be time to ditch it for that other app?
Frank Ferrucci
Frank Ferrucci
http://www.ferruccimusic.com
Re: It's done. :)
Be sure you know your movers, Vladimir!MIDI Life Crisis wrote:... and I get to use my own piano.
Shoosh
Re: It's done. :)
It fits in my Fit.
Re: It's done. :)
Hopefully that last report on the transition. I know a few of you are thinking about it. It's a bit of a financial leap when compared to previous purchases. The peripheral thing is still a work in progress, but it's mainly wanting more HD space for projects and how to setup TimeMachine in the new configuration. With two external FW 800 drives connected and a USB3 dock that functions well, I ended up with one more drive than I had before. The only SSD is the internal in the MP. Ten second boot from the chime. Network is way faster. Oddly, on my old machine and on this one as well, google.com is nearly dead. Very slow to load if it loads at all. More often I get a server not found! Not so on the phone or my wife's machine. It's not a Little Snitch thing blocking it. It just does not like Google. Bing is the workaround.
Quickeys was not working well. Slagging along and missing commands but only sometimes. It ends up that Xtra Finder (which I use) needed an update and now QK is working just fine again.
In the HD dept., the USB3 dock ($80 at Fry's) holds two 2.5 or 3.5 disks (or some combination thereof) and is super fast. (Cirago one touch cloning thing).
Track 16 does NOT like the USB connection but it's fine with the TB to FW800 cable. Completely non-functioning via USB.
Otherwise it's back to all systems normal. I'm really glad I never ditched the external USB DVD drive (Lightscribe from Lacie). Campus 100 now off the system as is the Focusrite 24 DSP Pro. The last remaining FW400 devices I had. But then there's the 8 core to deal with so I can use 'em there.
Authorizations weren't too bad. Best done outside of DP and not as the VI is running. Yeah, I talking to you, Korg! Word and FCXpress needed licenses as did CS5 from Adobe and Finale.
Feels very "clean" and easy to deal with the actual machine. Not like that big cheese grater that comes home Tuesday. I'll keep it as an emergency backup for a while. Maybe try farming it although I doubt I'll even need that kind of speed.
BTW, my audio buffer sizes in DP jumped to 4096. I guess that's a good thing... and I still got a shiaaatload of wires to deal with... and that's the easy part!
Re: Transitioning to a Mac Pro Trash Can (one perspective)
Here's twist... iTunes DEOS NOT like to go into the visualizer and it consistently crashes iTunes. Hmmm... I suspect that TB to DVI via a $30 cable (and two monitors) may be to blame, but I just don't know. Report sent to Apple. I'll run a movie and hope it's not going to be a problem systemwide...
When you say it doesn't like Google, what browser? Safari is still buggier than hell and Firefox still has security holes--it just changed its default to Yahoo which is giving some people grief.
Google docs works best on Chrome, even though it's still 32bit.
Did you install both the 32bit and 64bit Java Run Times that Yosemite requires?
The 32bit Run Time (JavaForOSX2014-001.dmg)
http://support.apple.com/kb/DL1572
The 64it Run Time (jre-8u25-macosx-x64.dmg)
http://www.oracle.com/technetwork/java/ ... 33155.html
Thanks. I'll run those for sure. I just assume they were in the OS already. Duh! Also, the graphics system crashed three times now. Once in iTunes with visualize and twice playing a DVD. The player is a Lacie via USB3. The reseller (Melrose Mac) said it could be a bad graphics card and to remedy it would mean swapping out the RAM into another machine, then copying my HD data to the new machine. Seems kind of extreme but the card doesn't come out of the Mac Pro so when it goes, the MP is essentially dead. I was also told just swapping out my HD is not an easy option. Huh? Say what?! I'm gonna be mighty pissed at Apple if either fails shortly after Applecare expires. Mighty mad... In the mean time, I'll keep using this machine until my old one returns and see if permission repairs help as well as continuing to tweak the system for errant software I may have installed.
When you figure out a cabling combination that is soft on the eyes please post as I have been consumed with cable madness for way too long.
http:www.davidosuna.com
