Can't drag/drop IR WAVs onto Pro-Verb
MDesigner
Post by MDesigner »
The manual says you should be able to drag and drop your own impulse WAVs onto the waveform display in Pro-Verb. But when I do, DP locks up on me every time. Can anyone else replicate this? Mac OS 10.9.5, running DP 8.07.
Sam Hulick
Composer
http://samhulick.com
Social Media: [ Twitter | Facebook ]
Re: Can't drag/drop IR WAVs onto Pro-Verb
There was a long thread about this a year or more ago. Dropping IR files onto Pro-Verb worked generally, but not all files work, and IIRC, I did get a freeze up from some. But for the most part it worked as advertised.
One thing I found is that when you want to add new IR files, it is best to delete the library Proverb creates using the Finder, and then drag all of your IR files back into Pro-verb to force DP to recreate the library.
