Loss of panning - recording via analogue desk
Studio Llama
Post by Studio Llama »
Hi all
Hope this day finds you well. I have a newb problem I'm sure someone can help with.
I am using DP effectively as a tape machine, recording my synths, guitars etc through a Soundtracs analogue console. Line in to mixer, tape out in to RME fireface in. From there I record down to a mono audio track in DP then once done, I send back out of the FF to a spare channel, tape in on the mixer in order to monitor and ideally, mix!!!
I don't have any pan control on the mixer however when sending it back out, I wonder if this is a limitation of the mixer, by virtue of the fact that I am sending it through the tape in, however, I don't think so. There is no pan control in DP either. I'm sure there is a good explanation for this, I just don't know it...
Thanks for any advices... :)
Gravity Jim
Re: Loss of panning - recording via analogue desk
Post by Gravity Jim »
You won't see pan knobs on mono tracks in the DP mixer unless the output is set for a stereo pair. If it's set to a mono output, there is nowhere to pan it to.
Jim Bordner
buzzsmith
Post by buzzsmith »
Jim, I can see pan knobs on my mono channels. Maybe the OP has "pan" unchecked in the mini menu in the far upper right corner of the mixer window?
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Gravity Jim
Rats! I knew I would get that wrong if I didn't open the program!
Jim Bordner
Tiny rats maybe. I think Jim had it right. If you set the output of a mono channel to a single mono output, the pan knob disappears.
buzzsmith
Post by buzzsmith »
bayswater wrote:Tiny rats maybe. I think Jim had it right. If you set the output of a mono channel to a single mono output, the pan knob disappears.
That could be. When I checked on a current compete project (still in final mix mode), all of my tracks, mono or stereo, were set to output to a common stereo output.
Buzzy
Focal Twin6 Be(s)
Gravity Jim
Okay, then I did remember correctly! It only stands to reason.... If its a mono output, then what good is a pan knob?
Jim Bordner
Studio Llama
Hi
Thanks for the replies, yes, it was a green newb moment, the fact I noticed something 'different' was because as Buzzy said, I had previously outputted both mono and stereo tracks to a single stereo out, hence why pan remained.. Sorted now, thanks again
Gareth
buzzsmith
Post by buzzsmith »
Glad you figured it out!
Buzzy
Focal Twin6 Be(s)
