I recently have started a recording company....im running a MOTU 1224 PCI-324....i also use a guitar port as a preamp for my guitars.....im looking at buying a cheapish but good vocal recording mic and a vocal preamp....im looking to get the best for a real low budget....any advice would be very appreciated....im currently lookin got stay below 500...just something basic that will clean up vocal tracks
thanks
john
Small low budget studio
Re: Small low budget studio
i'm not a big specialist here but the Rodes I heard seemd to be okay, I use a AKG C2000 which is fine but the Rode is even better.
Just my 2 cents
Just my 2 cents
G4 Silver 733 / OS 9.2 / Motu 1224 / Fastlane
DP-3.11 / Reason 2.5
Roland MB-D1 / JV-1010 / U-220 / Korg X-5
There are plenty of good vocals mics under $500. Audio Technica, Rodes and Studio Projects all make decent products in this range. You'll be hard-pressed to find good mic preamp alone for under $500 however.Originally posted by MuzicNerd:
Nevertheless, if your budget ceiling for both preamp and mic is $500, I'd recommend:
</font></li>[*]<font size="2" face="Verdana, Helvetica, sans-serif">Preamp: Studio Projects VTB-1 (around $100)
</font></li>[*]<font size="2" face="Verdana, Helvetica, sans-serif">Mic: AT-3035 or Rode NT1-A or Studio Projects C1 (all around $200).
Although this'll keep you around the $300-and-some-change range, the weak link in this chain is definitely the preamp.
If you can up your budget a little to $600, you could get a Groove Tubes Brick (around $400) and any of the above-mentioned mics. It'll up your quality noticeably.
Finally, I assume you know you'll need other things to makes vocal recording even marginally workable (e.g., mic stand, popperstopper, some kind of acceptable vocal recording space, etc.).
Good luck.
