Merge Soundbytes into One
I want to take two mono soundbytes on different tracks and merge them into one mono track.
For example, Soundbyte 1 plays the piano right hand measure 1 -8. Soundbyte 2 plays the piano left hand measure 1 -8.
I want to merge them into one mono piano track that contains both the right and left hand, rather than two separated mono tracks.
How do I do that?
How do I do that?
DP 11.31, Mac Studio M2 Ultra, 128GB Memory, Sonoma 14.3.1
Re: Merge Soundbytes into One
Mono bus both to a mono audio track and record that.
DP8.06 PT11.2.0 VEP 5.3.x
- Radiogal
Bounce is your best friend here
MAC PRO 6 Core 3.33 GHz, 16 GB RAM, OSX 10.8.5, DP 9 MAC and WIN (64bit/Jbridge) AMPGUI Mellow, Logic 10, Wavelab 8 MOTU 24I/O (x2), MOTU 2408 MK3 (2x), WAVES Mercury 9, SSL, UAD2Quad, McDSP, Sound Toys, Sonnox, Sonalksis, NomadFactory, T-Racks, P&M, LexPCM, AbbeyRoad, DSM, VCC, VTM, FGX, Melda, EWQL SymphOrch/Piano Gold. Mixingdesk: AMEK Big 44, TK BC-1MK2, SSLcomp clones, GAPPre73, PCM91, TC, FMR. Monitors: Genelec 1031, ADAM A7, >40 mics http://www.ragdollproduction.com
I can bounce to a mono .WAV?Radiogal wrote:Bounce is your best friend here
- Radiogal
Set the FOLDDOWN on the master track to MONO.
However NazRats solution will work too, and is probably even better.
How do I set the folddown to mono?Radiogal wrote:Set the FOLDDOWN on the master track to MONO.
- Radiogal
Every Master fader has a folddown option in the Mixing board.
