Doppler on steroids?
I need to smoothly ramp down the pitch on a sound effect over a few measures without affecting the rhythmic pulse, kind of like the doppler effect of a siren going by but going down in pitch much lower. The soundbite doesn't show up well in the pitch editor the way an instrument or vocal does. I'm planning to segment the soundbite and shift each seg. individually down incrementally but I would prefer a smooth ramp. Is there a way to do this with DP? Thanks.
iMac 27" 4.2 GHz i7 1TB SSD. 40 GB RAM. Apogee One.
Re: Doppler on steroids?
I doubt the pitch tool could do that but I've never used it so I'm guessing.
MachFive 3 would make easy work of it with the IRCAM stuff.
I just checked out Mach fives promos, that is amazing how well it can alter audio without trashing it!! So it looks like I need something much more specialized to try what I wanted, even expecting less pristine results. That makes sense, thanks.
Side bar, this is the second time in a row my post went up twice, I'm really not trying to do that and it looks like I can't delete it once it goes up. Sorry to the boards for making a mess.
- BKK-OZ
If Doppler is what you are after, you might want to look @ http://wavearts.com/products/plugins/panorama/
Cheers,
BK
- M Kaku
BK
- M Kaku
OMG is that cool!!! I don't get how they do it even after reading the explanations but it's awesome. As far as that particular part I was thinking how as the sound passes and the waves get longer the pitch seems lower but now this has opened a whole new door.BKK-OZ wrote:If Doppler is what you are after, you might want to look @ http://wavearts.com/products/plugins/panorama/
You could use QuikQuak Pitchwheel to do this and other kinds of pitch/timbre manipulation (e.g., tape stop effect). Hint: use the Smooth control to precisely control the rate of pitch change. Can be used statically as a pitch or timbre-shifter, too.
http://www.quikquak.com/Prod_Pitchwheel.html
Mac Studio Max | 32GB | 14.5 | 828es | M4 | DP 10.13 | Studio One 6.6 | Logic 11
tremo wrote:You could use QuikQuak Pitchwheel to do this and other kinds of pitch/timbre manipulation (e.g., tape stop effect). Hint: use the Smooth control to precisely control the rate of pitch change. Can be used statically as a pitch or timbre-shifter, too.
That seems to be very straight forward for what I was imagining. Thanks!
