Drag to left pane in TO in 8.05 Crashes DP [RESOLVED]
Drag to left pane in TO in 8.05 Crashes DP. Can anyone confirm please?
Mac Pro 2X quad core 2.26 Ghz, 22 GB RAM, OS 10.8.4 | DP 8.05 | 2408MKII
Beta Tester for Toontrack
Re: Drag to left pane in TO in 8.05 Crashes DP
Works ok here. 8.05 in 10.9.0 on a MacBook Pro.
- Gravity Jim
Also working fine here.
Jim Bordner
Dragging WHAT to the left pane? Sound files? MIDI data?
It started out with some sort of corrupted conductor track clipping, then after that crashed dp, all other audio files dragged in to the left pane in the Tracks window crashed dp as well. But after a reboot all is back to normal.
Re: Drag to left pane in TO in 8.05 Crashes DP [RESOLVED]
Dragging in audio files even after mac reboot, also crashes dp now, crash log sent to MOTU.
Tried with the "safe" set of plug-ins only, also crashes.
Working fine here as well. You might want to trashed the DP plist(s) and possibly reinstall the app.
Thanks, will try that, it works fine in SE though, but not in TO.
Those windows do work different when dragging stuff in. Unless it's changed since I last tried it, dragging into the TO window where no specific track is dragging into will (with soundbites) create a new track. In the SE all you can do is add to t attack. SO it might be that DP is somehow having a problem either crating or deciding whether or not to create a new track.
Just my guess.
Just my guess.
I am always referring to dragging into the left most side of both windows. In the SE if you drag an audio file onto the left most section it will create a new track as well, like in the TO.
As for deleting the plist, can you please point me to where that is? Thanks.
Looks like it only really erected one particular corrupted session. Sorry for the head aches and thanks for the help....
- primeevolutionary
This is kind of an old thread, but, I just had the same problem as you dragging in soundbites from a ProTools X session. I wasn't able to drag from the Soundbites window into Tracks.
I was able to drag soundbites one by one into the Sequence Editor.
I usually keep my Mixing Board and Tracks window as separate windows and use my Sequence window as a consolidated window with the Channel Strip.
For the heck of it, I decided to try to drag multiple soundbites into the Tracks window (the left side of Tracks) as a consolidated window and that worked just fine.
I've never had this issue since switching to 64 bit, but, here's a possible work around I guess.
OS X 14.5
DP11.31
Stage-B16
2 828 mk1s
MTPAV USB
OS X 14.5
DP11.31
Stage-B16
2 828 mk1s
MTPAV USB
