I use MV 3.1.4 and am currently writing a review.
If I import a rex the convert button does nothing.
I can drag it to an empty part though and then it works like expected.
However, then I only see the mapped Keygroups and not the Looplab including the too to drag the MIDI File over to the Sequencer. So this does not work as expected. I can only get along with the map Button.
Convert Button in Loop Lab with Rexes not working?
Re: Convert Button in Loop Lab with Rexes not working?
Convert is a drag n drop button which create a M5 program so you can either DnD it on the Desktop or to another M5 part.
If you want to keep the MIDI functionality then just use Map (little keyboard icon next to convert).
Don't understand what is your problem.
