dumb monitoring question
JES
Post by JES »
Hi All,
Here is an extremely dumb 1402VLZ question, but I can't figure it out.
My Sampson monitor control thingy just died, so I've gone back to using my mackie 1402vlz to monitor 2 channels of sound coming out of my computer-based DAW. I'd like to know how to set it up so that I can press a single button and mute my monitors (powered) while still being able to hear signal through headphones. Extra bonus if there's a way to control the two volumes independently of one another. I'm sure there's an obvious way to do it, but I haven't figured it out.
Thanks.
--JES
RobTalbert
Re: dumb monitoring question
Post by RobTalbert »
I haven't used a Mackie mixer for a few years and don't have one in front of me...but this might work:
Assign the 2 channels that you want to monitor to ALT 3-4 by pushing the mute button on each of the 2 channel strips. Then in the Source Matrix, engage ALT 3-4 and you should be able to hear the signals through the phones. Press the ASSIGN TO MAIN MIX button and the signals on ALT 3-4 will also go into the main mix. (Presumably these are wired to your monitors.)
I hope this works for you.
iMac M1 with 16 GB RAM, OS X 12, DP 11, Focusrite Scarlett 18i20, Waves Plugins, Melodyne, Kontakt, BLUE Kiwi and Neuman Mics & BLUE Robbie Pre; Martin D18, Martin OM25, Cordoba, & PRS CE24 Guitars.
JES
Post by JES »
Thanks Robert, I'll give it a try.
--JES
