Is there a way to tell DP, programmatically, how to name audio files when it's recording? I'd like to be able to have it put the timecode somewhere in the name of the audio file automatically, so that when I'm recording a bunch of stems I don't have to go through and update every one if the cue starts 2 frames earlier or something. Some interpolation input, like "#{chunkTitle} - #{trackTitle} - #{take} #{timecode}"... I know this is a kind of wishful thinking but I figured I'd ask if there was at least something similar to this functionality.
Automatically/programmatically name audio files?
- FMiguelez
Re: Automatically/programmatically name audio files?
AFAIK, the only way is to let DP grab the Audio File name from the track name (you do this from the Audio window - sorry, not in front of DP now to check the window name).
The other choice is to manually name them as you go right there in that same window.
This is probably not what you want because you'd have to rename every track...
I suppose you could ask MOTU for this feature.
Seems like naming them after the track has been a good idea. But changing the name is easier than ever.
I'm not sure how else you'd communicate to DP just what you want to name it. Maybe an iPhone-device into which you whisper "Siri, name this track Mondo Bondo." Hopefully the mic doesn't pick it up, or when Siri misstates it back to you: "Now deleting your Monday condo closure meeting."
Hehe... I was thinking it would be nice if DP would provide a way for you to tell it how to name tracks with variables. So it might provide you some options in the "Audio Files" preference menu:Shooshie wrote:I'm not sure how else you'd communicate to DP just what you want to name it. Maybe an iPhone-device into which you whisper "Siri, name this track Mondo Bondo." Hopefully the mic doesn't pick it up, or when Siri misstates it back to you: "Now deleting your Monday condo closure meeting."
Audio File Name:
[ ] Use the Track Name
[ ] Use the Track Name + Take Name
[ ] Custom: __________________
And it might provide a few possible variables:
- trackName
- takeName
- chunkName
- date
- timecode
So one might fill it in like:
Code: Select all
{chunkName} - {trackName} v{takeName} - {timecode}
Code: Select all
m01 - Credits v3 - 05010315
