Hi:
I'm trying to use the ADAT outputs on my Presonus AudioBox 1818VSL as an expansion to my MOTU 828MK3. Can't seem to get signal in CueMix. Using the Presonus ADAT as clock master. Both devices are set to same bit depth etc. ADAT is set in MOTU audio setup Optical A.
Is there a setting I need to change in Mac's Audio/MIDI utility? Specs in my signature.
Thanks......
Can't get signal ADAT input MOTU 828MK3 (FW only)
MacBook Pro 15" 2G QuadCore i7,8G RAM, 20"Intel iMac 2.4Ghz , 4G RAM.OSX 10.8.3 on both, DP 7.24, MOTU 828MK3, AudioBox 1818, KRK Rokit 6G2, Omnisphere 1.5, Komplete 8, Amplitube 2&3, SampleTank, Sonik Synth2, SampleMoog, SampleTron, Ivory 2, Philharmonik, EWQL MOR, SC, SOG, SD2, Reason 6, Waves, McDSP, Slate Digital VCC, FGX, Sound Toys.
Re: Can't get signal ADAT input MOTU 828MK3 (FW only)
Do you have to set up a mix on the 1818 to route the analog inputs to the ADAT outputs?
DP8.06 PT11.2.0 VEP 5.3.x
