DP 7.24 with Demo of DP 8
Quick question...If I install the DP 8.02 Demo in my computer, will 7.24 still work as always (very well i might add) if I decide not to upgrade.?..Thanks
Re: DP 7.24 with Demo of DP 8
DP 7.24 will almost run as always after installing the 8.02 demo. You will lose lameframe for making mp3's, and I lost the .midnam file for my Korg keyboard patches.
Mac Pro 2x2.4 quad core /24 gb ram/OS 10.13.6, Dp 10.13, MTP AV, /UAD 2, KOMPLETE 12, Stylus RMX, SD 3.0, EZ Drummer 3, A&H ZED R 16.
Well wait a minute. We lost the LAME MP3 export in the earlier version of DP 8 (.00 and .01) but now MOTU has included that in the install package so I don't know if it will ruin DP7 MP3 exports or not. I'm hoping it won't but i"ll not need DP 7 unless I want to use the Waves ultra pitch plug as it is dead in DP8 in my system (but fine in DP7). Go reconfigure.
- waterstrum
DP8 will mess with your DP 7.24 control surface drivers.
If you have a complex setup of these...
Best to save that folder before you install.
Just found out that DP8 also kills mp3 export in DP7.24.
Now I have to go back and remember how to install the Lame thing.
All is well
Hi Bman....bman wrote:Quick question...If I install the DP 8.02 Demo in my computer, will 7.24 still work as always (very well i might add) if I decide not to upgrade.?..Thanks
I lost Invert Phase plug and Lame in Dp 7.24 and Invert phase plug in DP 8 when I upgraded to DP 8 (demo)
Since I use invert phase a lot, I wiped DP 8, had to reinstall Invert phase plug and download 7.24 to get the Lame working again in 7.24.
Since I need to finish some big projects, this was a big deal... and the trim plug has an invert phase in it - but it sounds quite a bit different to me than the invert phase plug so I don't bother with it.
M
a
x
OSX 10.7.5 / 2.66 Ghz Intel Core 2 Duo / Motu 8 pre / DP 7.24
a
x
My 7.24 still works as well as it did. i did notice however, that when i opened a new project in 7.24, it saved it as an 8.02 file. Not an issue really, because i just use the "Open WIth" command to select 7.24
MacBook Pro 15" 2G QuadCore i7,8G RAM, 20"Intel iMac 2.4Ghz , 4G RAM.OSX 10.8.3 on both, DP 7.24, MOTU 828MK3, AudioBox 1818, KRK Rokit 6G2, Omnisphere 1.5, Komplete 8, Amplitube 2&3, SampleTank, Sonik Synth2, SampleMoog, SampleTron, Ivory 2, Philharmonik, EWQL MOR, SC, SOG, SD2, Reason 6, Waves, McDSP, Slate Digital VCC, FGX, Sound Toys.
