Freezing Audio tracks seems a very slow process...
- FMiguelez
Re: Freezing Audio tracks seems a very slow process...
You are almost there, Zandurian!
I should've given you this link earlier... I just remembered about it.
I'm pretty sure you will like it a lot. Check it out
http://www.motunation.com/forum/viewtop ... 4&p=423536
Yep - I like a lot!FMiguelez wrote:You are almost there, Zandurian!
Because you didn't have you to tell you then as I have you to tell me now.FMiguelez wrote:
How could I not know about this until now?!!?
Mac Pro (early 2009 - originally 4,1 - flashed to 5,1) 2 x 3.42 GHz 6-Core Xeon X5690, 64 gigs PC3-10600 RAM, OS 10.13.3, DP9.52, UAD2 duo, UAD2 solo,
Superior drummer 2, Mach 5-3, Ivory, PCIe 424, BL modded 24i/o, MIDI express XT, unisyn, Melodyne 2, Izotope RX2, Addictive Drums, Pianoteq
Great quote BTW! Didn't know he was a member till now!Richard Feynman wrote:“In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth.”
Funny thing: Feynman said that with such certainty that it is not surrounded by uncertainty, and therefore cannot be the truth. And if it's not the truth, then he's lying, which means that what is surrounded by uncertainty can't be true, or to look at it from the other side: that which is said with certainty must be true. So that means Feynman is telling the truth, which means he's lying, which means he's telling the truth, which means…zandurian wrote:Great quote BTW! Didn't know he was a member till now!Richard Feynman wrote:“In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth.”
WHEW! Don't ever trust that guy Feynman! Even when he's telling the truth, he's lying!
PS: Feynman would love that argument!
- FMiguelez
I'm sure we would!Shooshie wrote: Feynman would love that argument!
Then, he'd find some other way to completely turn it around, confuse us all, and kick our arse!
Richard Feynman is one of my favorite people who ever lived.
If anyone hasn't seen his famous physics lectures, you owe it to yourself to do so. It's like watching Albert Einstein delivering knowledge, with a Noo Yoak accent, and everything
Great scientist, thinker and educator
UPDATE to ML 10.8.3... (open image in new tab or window for full pict)
Last edited by MIDI Life Crisis on Fri Mar 15, 2013 7:26 am, edited 1 time in total.
- FMiguelez
Wow!
So are you saying the freezing timing issues got magically fixed with this update?
I'm not saying anything. I'm simply presenting evidence as before. But your observation appears to coincide with mine. Yes, it appears to fix the issue and the update specifically mentions plugins for audio. That's big.
Meaning OSX 10.8.3 MLC ???MIDI Life Crisis wrote:UPDATE to ML 10.5.3... (open image in new tab or window for full pict)
Yes. ML= Mountain Lion. In all the excitement I thought I was back in SL. Sorry. So again, 10.8.3.
- doodles
I'm jealous that it's working for youFMiguelez wrote:doodles wrote:
Hi, Doodles.
Thanks for clarifying, but I must confess I really can't see what the problem is...
My template is quite large too, and it never takes me longer than the duration of the cue to print all my MIDI tracks individually.
Can't you just print them in real time? You just need to set up some smart routing tricks, but it's totally doable. Why do you insist on using Freeze? Real time printing gives you the same results, only faster, better, and more reliably.
It seems that there have been mainly 2 issues in this thread:
1.- That Freezing is not faster-than-realtime
2.- That DP crashes when freezing more than a few tracks at the same time.
For 1, that's the way it is. It is a real time process and one can not expect it to go any faster (as opposed to BTD, for the reasons I've outlined up-thread).
For 2, THAT is an issue. DP should be able to freeze 3, 15, or 100 tracks at the same time with no problems at all.
Doodles, this seems to be your one and real problem, correct? Otherwise, if it worked as it should, you'd be happily freezing away all your tracks with no wasted time, yes?
If so, MOTU needs to know about this, because it should not be happening at all.
Also, if you take into account this other disturbing freezing-realted thread, MOTU must really roll up their sleeves and find out what is going on with the Freeze command.
Basically, people are seeing crashes when bouncing multiple tracks at the same time, AND other users are experiencing totally inconsistent timing issues when freezing, according to this thread:
http://www.motunation.com/forum/viewtop ... =1&t=53597
THAT I find very disturbing. I never trusted BTD or freezing, and this seems to only confirm my suspicions that these methods are not always reliable and are prone to timing/phasing issues.
MOTU?????
Some members seemed a bit confused between bouncing and freezing.MIDI Life Crisis wrote: Also, given that freezing takes at least as long as realtime in any instance I've seen personally, freezing makes little sense. If I am understanding the reason for it at all, it's to basically bounce the audio but w/o FX plugs. Maybe someone could clarify (I think FM already did but can't find it) that I understand that correctly.
Basically, freezing works AT THE TRACK LEVEL. It'll print the track's automation and plugins, but it will NOT print anything that was delivered via sends. This means no reverb, no delay, and no automation/plugins in any submix or stem aux tracks.
Bouncing, OTOH, will include all of that, providing that the right tracks are play-enabled. But doing this track by track would not be efficient or desirable at all. This is not BTD's Raison d'être. BTD was designed to "merge" or print more than one track at a time (i.e., your final mix, or stems).
It's gotta be a VEPro/DP thing. i know I'm pushing DP pretty hard, but it's crazy. Recording in real time just doesn't seem feasible. So my template is (I just did a rough count) around 400 MIDI tracks. If I was to have this set up with routing to try and record all at the same time, I would have to have 400 aux tracks permanently set up for routing? I know I'm prob being thick, but it's a convo I've had with quite a few people recently. Just can't find a wat round it. I DREAD the tracklaying process!
so in short, yes you're right.
a) freezing isn't faster than real-time. I couldn't care less.
b) freezing tons of VI's crashes. Yes this is my main issue.
Again, apologies for delay replying. last 3 weeks of this, then I WILL do a separate topic and you can all ignore me for being so thick
2*5-core 3.46 Intel xeon (32 gigs RAM), 2*dual 2.5 (16 & 32 gigs RAM), DP 8.07, WAVES 9, Lexicon plugs, SoundToys, all Spectrasonics, NI Komplete 9, Vienna Ensemble (extended), LASS, Evolve, Symphobia, etc, Cinesamples, Arturia, cinestrings, all Project Sam
