Mach Five and Electric Keys
Posted: Wed Sep 19, 2012 9:24 pm
Mach Five 3 seems to automatically mount UFS files in C:\Program Files\UVISoundBanks.
Electric Keys likes to find its UFS files in C:\Program Files\MOTU\ElectricKeys\Sounds.
I tried creating Windows "shortcuts" in the Mach Five directory pointing to the original installation of Electric Keys UFS files but it just complained that it couldn't read the files. Windows is appending .lnk to the name ... but doesn't show me that in the window, I only see the UFS extension. Is there something tricky I need to get the links to work correctly?
Otherwise, do I physically need to copy all those samples to both locations ... and then again for the x64 and x32 apps? Ableton Live is still running at 32bit and likes to look in C:\Program Files (x86)\... whereas Cubase is checking C:\Program Files\ ...
I'm sure this is wrong ... but currently I'd have to have 8 DVDs copied to 4 places?
Is there a configuration setting, in either app, that lets you define "custom" or "additional" UFS directories - much like the way an IDE lets you add "include" directories?
For Electric Keys 64 and 32 bit versions, maybe I can create a shortcut to the "Sounds" directory instead of the actual UFS files .... will try that even though that still doesn't solve the Mach Five issue.
Thanks in advance!
-Luther
Thanks in advance!
-Luther
