I'm now using VideoSlave to host video instead of DP, why?
Posted: Sat Sep 08, 2012 1:14 am
Hey guys,
Just wanted to share and amazing new program that is out that has allowed me to off load the video hosting from Digital Performer to another slave machine...and let DP focus on MIDI and audio...and not drive video. The new program is called VideoSlave and is from a German Developer. Here is the webpage for it.
http://www.non-lethal-applications.com/ ... r-vtr.html
This program really came about when film composer Charlie Clouser (From N.I.N. and of the SAW series of films) approached a German developer about the need for a simple and solid VTR program for hosting QTs that can sync to MIDI Time Code over a network. Hence, VideoSlave was born. Full disclosure...I have been one of their beta testers as well. But I get nothing for mentioning it here. I just think the developer Flo has done an amazing job here with his program making it simple and powerful. And I truly feel it is currently the best elegant solution for hosting video in Post-Production out there. And the fact that it will work alongside DP...or ProTools...or any DAW...is awesome.
Why is this a good thing?
1. By no longer hosting the video in DP on the same machine...you can save from CPU on your DAW to further squeeze out as much as you can for other plugs and VIs.
2. VideoSlave can take pretty much ANY kind of video, codec, frame rate, etc...unlike DP which tends to be best with certain codecs and can only currently output full screen video via Firewire and DVCPRO codec which is NOT Hi-Def.
3. With VideoSlave you can take an older Intel mac or Mac mini, laptop, etc...and use it to drive the video. Have DP output MTC any way you can (over a network or MIDI device)...and VideoSlave will sync in under a second. It can also run full screen with no QT controls so it looks like a genuine VTR. Run that output to your monitor or projector and your studio will have full screen video being controlled by DP...but driven by VideoSlave on its own little machine.
4. I currently use one of my Virtual Instrument MacMinis to not only host LA Scoring Strings and Storm Drum 2 libraries...but also to drive VideoSlave and it works solidly.
5. You can create playlists of QTs. When scoring a movie in multiple reels...you can load up all 5-6 QT reels in the playlist...and VideoSlave will keep them in order and instantly jump to the next reel as your DP or ProTools session advances its timecode.
Check it out for yourself. There is a demo that will run for 5 minutes at a time.
The price is only $250.
