Greetings,
I would like to synchronize videos with Audio inside DP and output the video and audio out of the same computer (i7 Dual core Mac Book Pro) for live performances. For what I understand, the only way to output the video is using the Firewire port. Is this correct? Can I play it out of the VGI port (through the DVI port in the mac)?
I guess I could connect the Audio interface to the USB port (instead of the Firewire) and use the Firewire for the video.
Please let me know your recommendations. Thanks in advance.
Is DVI/Firewire the only way to output video?
Re: Is DVI/Firewire the only way to output video?
Hang around for DP8 - soon we hope - the video implementation is going to be much better so you can output full screen video to any computer monitor in HD. As you say, the current full screen option is only available through FW to a DV device at standard definition.
This is going to make a huge difference!!
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
I'm confused, doesn't your macbook pro have a mini DV port? I run my video screen out to an external monitor using the DV port and my audio out through an 828 using firewire every day. So no, audio does not run out of the mini DV (mac didn't make this possible with mini DV) but runs in sync with the 828. Even if you didn't have an interface, you could just run audio out of your 8th" out.
I use this for film scoring sessions where we conduct large ensembles in the studio to the DP sequence with punches and streamers on it.
I'm not outputting both through the same output, but it's from the same computer.
Let me know if this even begins to solve your problem.
Thanks for your reply!! This would be great; I am going to test this out. I do have a mini DVI port on my Mac pro and have an ultra lite interface.
I will let you know.
