Exporting Marker Information to other DAW's?
Hello,
Is there a way to export marker location information from a DP session?
I need to send a DP audio file to a client with marker information locating
where the VO talent started a new prompt and stumbled so that the client may edit
to his discretion saving us all time. Client uses a different DAW.
Any one know if this is possible in DP?
Thanks ever so much,
J. AudioRichter
J. AudioRichter
Re: Exporting Marker Information to other DAW's?
I think if you create a Standard MIDI file in DP and import it into another DAW it should retain tempo and markers.... at least that is how it works going from ProTools and Logic to DP....
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
How about just listing some SMPTE time addresses?
Just checked - in DP do a Save As and select Standard MIDI File as the file type.
It carried my tempo and markers into ProTools.
Cheers
Stephen
Cheers
Stephen
Thank you so much for the reply,
Unfortunately, this does not seem to work for me. I am exporting as a MIDI file and no marker meta data is transfered when I open the MIDI file into another DAW. Is there a simple step I am missing? Are you hi-lighting something I am not?
Is there a specific file format in the "MIDI File Options" window you are checking?
Format 1, 2 or 3? Checking "Save track names as plain text" or "Expand loops and capture effects" (though I don't see what the last two have anything to do with the dilemma...)
All the markers are unlocked.
Thanks so much for your patience and time.
J. AudioRichter
J. AudioRichter
Is it because I do not have a MIDI track open?
- In a quandary... J. AudioRichter
Maybe try creating a blank MIDI track before saving
I tried it in a blank DP session, no tracks just a few random markers,
Save As Standard MIDI File
Format 0 - Tempo/meter map only
Open a blank ProTools file
Import MIDI - and there are my markers and Tempo.
Don't know what else to suggest - what are you opening it in??
Cheers
Stephen
Cheers
Stephen
Make sure End File at time: in the Save dialog is displaying the time at the end of your sequence - or the last marker
Or print the markers window if you want a list.
Tried creating a blank MIDI track before saving. No luck... :\
Tried placing a MIDI not held through audio recording. No luck... :\
As I am not used to working with SMPTE in a grand scale, Stubbsonic, what is the process for listing?
Any more great ideas to try, friendly DP cohorts?
Thanks so much!
Thanks so much!
It is not a list that I need. It is for the markers to appear as transferred meta data into their DAW session.
Thanks for the idea, MIDI Life Crisis.
J. AudioRichter
J. AudioRichter
I am transferring from DP to Re@p3r. I have just e-mailed the client the .mid file to see if it will work in Sound Forge, which he uses.
*fingers crossed* (Hopefully, the issue is Re@p3r)
Keeping you guys posted...
- Dwetmaster
If you want, you can send me your MIDI file and I can confirm the your marker information is there? PM me if you're interested.
Are we sure this isn't a problem with Re@p3r?
