I have just tested Kontakt 5 full.
I have found that when I make a change in Kontakt and hit “save” in Dig Perf, save is unavailable\, as if DP doesn;t notice anything has changes based off of changes in Kontakt.
If I close or crash at such a time, none of the changes, including all of the sounds added in Kontakt will save.
However, just like in the instructions Melodyne gave me for saving Melodyne in Dig Perf, if I move a slider or do any sort of movement INSIDE OF digital performer that DP recognizes, then save IS available, and changes made in Kontakt will be kept upon next start u,p after a crash or quitting, etc.
Can any other DP users verify this quirk of using Kontakt inside of DP?
Now I think I know why I have lost patches in Kontakt in earlier songs.
You have to nudge something or ake a recognizable change INSIDE of DP.
I personally just toggle the record overdub button in DP, which is harmless, yet still alerts DP to a change for saving.
Saving Changes made to Kontakt in DP Bug? Quirk?
- toodamnhip
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Re: Saving Changes made to Kontakt in DP Bug? Quirk?
Well I've noticed this with other VIs before... just ran a quick test with MachFive and Omnisphere, and the behaviour is the same.
Always best to look at the File menu before closing/quitting the sequence, I guess!
Stephen
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
- toodamnhip
Are you telling me that with MOTUs proprietary Mach 5, changes INSIDE of Mach 5 are not rememebred or saved unless nudging a save-recognizable function OUTSIDE of Mach5?stephentayler wrote:Well I've noticed this with other VIs before... just ran a quick test with MachFive and Omnisphere, and the behaviour is the same.
Stephen
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
Seems to be so, I'm afraid..... maybe it is common to all VIs regardless of who made them... will investigate my others a bit later on.
Cheers
Stephen
Cheers
Stephen
- toodamnhip
Seems like a really goofy Bug or oversight.stephentayler wrote:Seems to be so, I'm afraid..... maybe it is common to all VIs regardless of who made them... will investigate my others a bit later on.
Cheers
Stephen
I am starting to understand why I have loaded certain files only to discover my VI’s no longer had settings loaded into them. I must not have nudged something in DP to allow it to know there has been a change.
Please do do that research, important stuff to know isn;t it?
I wonder if this is anywhere in the manual?
Mac Pro (Late 2013
64 GB 1866 MHz DDR3
Mojave
DP 10.13
64 GB 1866 MHz DDR3
Mojave
DP 10.13
