Not sure why it's not letting you post the name of the DAW in question (is it "*Reaper"?). The MIDI specs for DP are excellent, and if you happen to be scoring film or video, it's flat-out amazing. Something I forgot to mention to both you and to Shooshie from his previous post: since DP8 is allegedly going to be able to use VST plugs, the Waves' AU/DP dilemma may not even be an issue. I hope that doesn't prohibit Waves from fixing their problems with their AU plugs working in DP, since I'd rather use AU over VST (and would rather not have the confusing issue of MAS/AU/VST all trying to run in the same DAW at the same time). Which begs another question .., does this mean MAS is still going to be a thing? And if so, does that mean MAS will now also exist in Windoze? I've suspected for a while (since DP4, actually) that they were eventually planning on scrapping MAS in favor of CoreAudio. Having DP use the native audio system (CoreAudio or Direct-X on Windoze) instead of MAS would make sense ...uoiva wrote:That is why I love R••••• 4 , not Reason ( why can´t the name be seen on the post ? ) . Because 90 % of all my vst plugins ( both 32 and 64 )works great .
*(Edit: it IS [name of program blocked out by author] [spaced out here to avoid censoring]. Weird that the message board is blanking it out!)
