Anyone Use the Mackie MCU Pro?
I am looking at the Mackie MCU Pro and trying to decide if mixing on a control surface vs. mixing within the DP software is worth it for me. My biggest question about the Mackie MCU Pro is: if you write automation on the Mackie itself and do a bounce to disc in DP (which is how I do my mix downs to stereo) will the automation moves be represented in the bounced mix down?
iMac 3.5 GHz Intel Core i7w/ 16 GB RAM, OS 10.8.5, MOTU 828 Mk III Hybrid, Digital Performer 8.05, Mach Five 3.2, Guitar Rig 5, Superior Drummer 2.0, MOTU Electronic Keys, tons of other plug ins (Waves, Antares, etc.) and VI's, Mackie 1604 VLZ Pro mixer, KRK Rokit 8 Studio Monitors, Yamaha NS10s , Gibson Les Pauls Standard and Studio, Fender American Stratocaster, Martin Acoustics, Mesa Boogie Mark V, Marshall JCM 800, Fender Hot Rod Deville, Trace Elliot TA200, Alesis QS 6.1
- Dwetmaster
Re: Anyone Use the Mackie MCU Pro?
The Mackie is only a controller so any automation you do with it will be written to DP. As long as you've enabled Automation-Record obviously
ah good point. So as long as I arm the automation to record in the DAW I would be all good. The only time to record the automation on the Mackie and not the DAW is if I were mixing down to an external medium. Ok totally makes sense. Thanks!
Not quite.. the Mackie doesn't/cannot record anything into itself, it has no onboard automation computer.. it only controls the DP faders, etc. in real time. The automation is always recorded in DP. If you arm a channel to record on the MCU, it's really just sending a command to DP, to arm that channel in DP.aaron_cabral wrote:ah good point. So as long as I arm the automation to record in the DAW I would be all good. The only time to record the automation on the Mackie and not the DAW is if I were mixing down to an external medium. Ok totally makes sense. Thanks!
Thanks for the info. I thought the MCU had it's own internal computer that would record fader and pot movements. But's thats ok, I would much prefer to have the automation done in the DAW anyway. The only thing I thought might be good about writing the automation information in the MCU is it would save CPU processing power on my iMac. Not a big deal though. I think I'm gonna get one. I miss actually touching the faders! Now what about the C4 Pro? I'm trying to research that one and it looks like they dont make it anymore? I wonder if it ever worked with DP?
- SixStringGeek
I have the original Mackie MCU and 3 XPanders. I got them as closeouts when the Pro version was released. I think the only difference is the panel color (dark gray vs off white) and the existence of an internal MIDI-USB gizmo to let it speak MIDI over USB.
I mostly like it, makes mixing moves nice and easy. I wish it had one more button per fader for toggling input monitoring. This is the only real drawback IMO.
DP 8.newest on MacPro 5,1 Dual Hex 3.33GHz 64G Ram, 3TB SSDs.
- Dwetmaster
SixStringGeek wrote:I wish it had one more button per fader for toggling input monitoring. This is the only real drawback IMO.
If you hold the "option" button on the mackie, I think "record enable" changes into an "input monitoring" button.
I will be very saddened the day that my Mackie dies. I'm glad that, after ten years, It's still going strong with virtually no signs of slowing down...
So will I, it´s proved durable and well worth it. I love my "big mouse" as a friend likes to call it.Dwetmaster wrote: I will be very saddened the day that my Mackie dies. I'm glad that, after ten years, It's still going strong with virtually no signs of slowing down...
http://www.cueaudio.org
Macpro 3.1 Octocore-16Gb RAM-OSX10.8 - DP 7.24
Macbook pro Core2Duo-4Gb RAM-OSX10.6 - DP 7.24
My console uses the MCU protocol.. it's more than a "big mouse" though.. I like to call it my R.O.U.S.zaratero wrote:I love my "big mouse" as a friend likes to call it.
- SixStringGeek
OMG I gotta try this. That would make my life most awesome. Actually, I never really use the select buttons, I'd be fine if I could remap those to do Input. Mostly I just use record, mute, and solo.Dwetmaster wrote:If you hold the "option" button on the mackie, I think "record enable" changes into an "input monitoring" button.
- primeevolutionary
Another old thread, but, I just can't seem to find this anywhere.
Thank you, Dwetmaster, regarding the option+rec combo. I had a work around, but, that will certainly be a timesaver.
What I'm trying to find out is if there is a combination or setting to control channel send pans.
If I hit the Send button and then Mode, I get a Pan option on the Master controller, but, it doesn't seem to do anything.
Is there a way to control send pans on the MCU?
OS X 14.5
DP11.31
Stage-B16
2 828 mk1s
MTPAV USB
OS X 14.5
DP11.31
Stage-B16
2 828 mk1s
MTPAV USB
I have 2. An older grey one and a newer one. As I posted before, I use one for DP and once in a while I couple the 2 together for 16 tracks. Or I use 1 for CueMIx for setting up a HP mix.
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
- Dwetmaster
Yes there is:primeevolutionary wrote:Another old thread, but, I just can't seem to find this anywhere.
1- Hit the button labeled I/O "on top of the "PAN" button"
2- You're now given a choice of options on your LCD, push the V-Pot that's under SndPan
3- The V-Pots are now linked to "Send Pan"
I Once made an Excel Sheet with all the Mackie Commands. Maybe I could ask James to "Sticky" it somewhere on the board.
- primeevolutionary
Awesome. Thanks again Dwetmaster.
I was at that menu, but, the one thing that I didn't try was pushing the V-Pot. I was turning it and hitting select and trying all kinds of other things. It's scary that, when it's in this particular mode (panning sends), that there's not much of a visible difference (Assignment shows P1 instead of Pn, but, I could easily see that being overlooked).
Anyway, I really appreciate it. That's going to be a huge timesaver.
Take care!
Take care!
OS X 14.5
DP11.31
Stage-B16
2 828 mk1s
MTPAV USB
OS X 14.5
DP11.31
Stage-B16
2 828 mk1s
MTPAV USB
Just invested finally in the MCU Pro. Awaiting the XT now.
