Im using a Novation Ultranova as controller keyboard.
DP 6.2
MX4 Vs 2? not sure..
When using the "MIDI keys" from the Studio menu as input device with MX4, DP event list for velocity notes read 98, that is good!. When using the Ultanova keyboard for input device velocity note reads 7, It should be 98. The volume/velocity is very low at 7.
I've used the Ultranova with other synths; Reactor or Novation synth Editor and the velocity reads 98 in the event editor for that note, like it should!... MIDI keys work fine for all other note velocities in DP event list with all other synths... Ultranova works fine with all other soft synths except MX4 velocity..
Velocity and volume are to low for MX4 when using the Ultranova keyboard.. Not sure why!
Ive checked the volume buttons in MX4, they are not moving through automation.. Thats not the problem..
Can you help... Thanks...
MX4: Velocity level to low in DP Event list
A.K.A DA BARON
