I believe you that it doesn't work.labman wrote:Vienna has told us that they tested it, and confirmed that it doesnt work at all on their rigs either.
I'm trying to figure out why it's "Semi" working on my rig...
With technically a 512 buffer (256 x 2) I'm only getting 5-10, sometimes max 20 samples off. Yes it's not as tight as with the Kontakt inside of DP, but it isn't 512 samples off..
If I do the Time shift plug, I only need to set it to around 10-15 samples earlier to get the desired tightness...
Did I just get lucky?? *knock on wood*
Regardless though, I really, really hope this gets solved. And not in a DP 8 form.. hopefully a DP 7.25. I really don't want to jump ship to DP8 and get involved in a whole other mess of bugs...
Although to add, If I change my buffer higher than 256 in DP.. yes, all goes out the window. I never change it when scoring with MIDI. I write and mix at the same time.. I only change it when mixing audio.. and in that case I don't use VEP... maybe that has something to do with it..
~Marc
