I heard that Sound Forge is coming to the Mac. This set of teasers is supposedly the proof.
http://finallyonthemac.com/
Best 2 track audio editor?
- Gravity Jim
Re: Best 2 track audio editor?
Jim Bordner
- ghobish
sayatnova wrote:One thing that makes me really annoyed is that due to PEAK not able to display "cocoa coded" plugins (I don't remember exactly what the tech support said), all of my most recent PSP plugs show-up as just a set of numbers and values with no GUI... I was told to down-grade the plugs if I wanted to see the actual PSP interface. Not acceptable. I use PSP plugs quite a bit. So, now I don't really use PEAK anymore (even the latest upgrade will not show the PSP plugsd completely so I am not upgrading).
It is indeed the cocoa vs. carbon issue. However, if you load the VST versions of the PSP plugs in Peak, you will see the proper GUI.
Gary Hobish
A. Hammer Mastering & Digital Media
San Francisco, Ca
http://ahammer.com/mastering
Mastering: Mac Studio M1 MAX 2TB SSD, 64GB RAM, 32-core GPU, OS 12.6; DP 11.22, Waves, Izotope RX10 Advanced, Alloy, Nectar, PSP stuff, Plug-In Alliance, Metric Halo ULN-8 MkIV, Euphonix MC Control & MC Mix, Presonus Central Station, and (still) no air conditioning (but at least now there is airflow)
Annex: Mac Pro 2010 5,1 3.33GHz 12-core, 80GB RAM, 10.14.6, DP 11.22, Metric Halo ULN8 MkIV, MOTU 2408III
San Francisco, Ca
- mhschmieder
Although, you won't have access to your custom presets if you saved those from an Audio Units instance.
So I have mostly been using Wave Editor for the PSP plugs and others.
Now that I own DSP-Quattro, I will try to learn it well enough to see if it can become my primary mastering tool.
