mikehalloran wrote:>Warning: SUID file “System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent” has been modified and will not be repaired.<
I decided to resurrect this thread than begin a new one.
This and the ACL message have recently been dealt with in Lion 10.7.3 and 10.7.4. Repairing Permissions no longer pops them up when you do it again (supposedly - it worked for me, however).
If, however, you get these messages:
Permissions differ on “
System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Support/Rem ote Desktop Message.app/Contents/Resources/pl.lproj/UIAgent.nib”; should be -rw-r--r-- ; they are drw-r--r-- .
Repaired “System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Support/Rem ote Desktop Message.app/Contents/Resources/pl.lproj/UIAgent.nib..."
...and so on, you upgraded your OS from 10.6 - or even 10.5 - and Repair Permissions will not make these lines go away.
It is true that these messages do not indicate a problem. Still, it can be annoying.
The only way to make this go away is to do a clean install of 10.7.4. You can use a system disk or a DVD of the download, run the many updaters, then restore documents, applications and user info via Time Machine.
If you purchased 10.7 from the App Store, this way works nicely. It installs 10.7.4 and saves time by eliminating most upgrade downloads when you are done (there will be two small ones but that's it).
To do a Clean Install:
Back up to Time Machine or a Clone
Boot into Recovery HD (Hold ⌘R on Boot) or Hold the Option key and select Recovery HD
Select Disk Utility
Erase Macintosh HD ("You did back-up, right?")
Quit Disk Utility
Select Reinstall OS X Lion
When prompted, select Transfer Data from a Time Machine or other disk)
I had some time on my hands yesterday and did the above - twice. The first time, I restored 645GB from a Time Machine disk connected via eSATA - this took about two hours from start to finish. The second time, I restored from a TM disk connected via USB - about 7.5 hours total.
The first time I ran Repair Permissions, it took 3 minutes and popped up 4 lines to be repaired; the second time I ran it, the time was 2 min. and the screen was clean - first time since 10.5.4, I think.
I probably didn't fix anything but some functions are noticeably faster including Repair Permissions - it used to take 12-15 minutes on Lion.
