Slow Down Audio & Bring Down Pitch Like In The Analog Days
(DP7 User)
Hi,
I had to tape a rehearsal with my drummer's old cassette recorder which was running slow (old batteries?). I converted the cassette recording to a digital file, but I want to slow it down so the tempo is right and the pitch is down about a whole step (bring the key back down to G major from A major).
Long ago, I did both pitch shift and time scale respectively, and I can refresh my memory about these in the manual, but I'd like to tie them together as if I were just slowing down the motor on a cassette player (too bad I couldn't take my drummer's cassette player as well as the cassette - this wouldn't even be an issue). Is there any way I can do that?
Feel free to point me to a term or particular spot I can look up in the manual rather than laying it all out for me. Any help would be greatly appreciated.
Thanks,
David
Hi,
Thanks,
David
Re: Slow Down Audio & Bring Down Pitch Like In The Analog Da
Put the audio files in a sampler and tune to taste.
Good advice.... DP itself cannot do the pitch change without time correction as you can in, say, ProTools, so a sampler is a good option, or there are other 3rd party solutions that I am sure others will recommend.
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Do you mean cannot do pitch correction WITH corresponding time change? (I want to slow down time and drop pitch).
- buzzsmith
"Amazing X" does both...it might be a reasonable solution. I think there's a demo. (Used to be called "Amazing Slow Downer".)
Buzzy
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Hmmm... that doesn't seem like it would sound too good! I just junk bad recordings that are lost for hope... sounds like there would b tons of artifacts.
Thanks for the Amazing X tip, Buzzsmith, I'll look into that.
As far as sound quality, you might say I'm using an anvil to crush an ant here - I'm just trying to listen to a rehearsal so I can make some comments to give to the band arrangement-wise, not to actually preserve the moment or create a final product.
Precisely. ProTools offline AudioSuite pitch change can change pitch only while leaving the timebase the same, or by selecting 'without time correction' option it acts like a varispeed.davidmkgrossman wrote:Do you mean cannot do pitch correction WITH corresponding time change? (I want to slow down time and drop pitch).
Unfortunately there is no such simple option in DP.
Cheers
Stephen
Still, if the batteries were wore down (or whatever) and the source was recorded out of speed then changing it back to the appropriate speed would induce formant artifacts... Oh well.
- KarlSutton
I'm confused I thought that's what the formants thing was for? In the spectral part of DP?stephentayler wrote:Precisely. ProTools offline AudioSuite pitch change can change pitch only while leaving the timebase the same, or by selecting 'without time correction' option it acts like a varispeed.davidmkgrossman wrote:Do you mean cannot do pitch correction WITH corresponding time change? (I want to slow down time and drop pitch).
Cheers
Stephen
MPB 17" 2.66 i7/8GB RAM, OSX 10.6.8, DP 7.24, 828 mkII, Ethno 1 via Ultimate Soundbank, MX4, MSI, Komplete 9, Ivory, Stylus RMX.
for a time:MacPro6,1 3Ghz 8 core 32GB RAM
The Spectral and formants thing is only suitable for mono audio anyway, and a change in pitch leaves the length of the audio file the same.
In a a nutshell, halving the speed on a tape machine would drop the pitch one octave and double the length. There is no facility built in to DP that can achieve this, so other solutions have to be considered, such as a sampler...... I usually just nip over to PT and use its AudioSuite pitch shift, or sometimes use MachFive within DP.
I have had to change speed on many tapes that I have digitised in the past that have been recorded on inaccurate machines.
Cheers
Stephen
Cheers
Stephen
Alright - time to install that pro-tools dvd I've been procrastinating about - feels like such a betrayal
- Gravity Jim
While we're discussing this, have any of you ever produced the "unplugged turntable" effect, where an audio file gradually slows down and goes lower in pitch at the same time?
And if so, can you do it with DP's stuff, or is there something else that makes it easier/cooler/better?
Jim Bordner
- KarlSutton
The only way I ever knew how to do that was with the lo-fi plugin in Pro Tools.Gravity Jim wrote:While we're discussing this, have any of you ever produced the "unplugged turntable" effect, where an audio file gradually slows down and goes lower in pitch at the same time?
Apple's AU pitch plug does the slow down turntable thing. It'll also probably work for the OP's needs. It should show up in DP for anyone with Garageband.
Either that or DP's own Nanosampler should work. Drag the audio file onto the Nanosapler and play your keyboard.
Don't think there's any need to do something as as drastic as open Pro-Tools.
DP 7.24, Focusrite 18i20, 3.06GHz Intel Core i3, OSX 10.9.5, 4 GB RAM, Reason 10, Kontakt, Motif +++
