Hello all,
I have VE Pro setup in server mode with a saved mframe64, made of 7 viframes each hosting 1 instance of Play. Whenever I switch/activate a MIDI track in DP there is a 2 second pause, and then the instrument bundles change from a stereo pair (L/R = NET3/NET4) to mono (L = NET4). Currently I'm only hosting Play libraries in VE Pro.
I've tried:
• With the VE Pro instance coupled as well as decoupled - same thing.
• Substituting a K5 instance in VE Pro server - same thing.
• Quitting all apps & restarting, repairing permissions, running Maintenance 3.8, etc - same thing.
I'm just a 3-day old VE PRo noob...please help!
Many thanks.
VE Pro Server changing the Bundles inputs?
DP 10.11 / 3.33GHz 12-Core, 10.15.7, 128GB / 3.33GHz 12-Core, 10.15.7, 128GB /
"The true sign of intelligence is not knowledge, but imagination." ~ Einstein
Re: VE Pro Server changing the Bundles inputs?
- wrathy
http://www.motunation.com/forum/viewtop ... ss#p397897" onclick="window.open(this.href);return false;
Sorry trying to do this on an iPhone...
There is a history of strange bundles behavior.
I have yet to experience it, but it's very painful!!
If you look at this thread, the first post has links to the other posts detailing the history of the problem, and some workarounds.
Hope that helps!
Best.
Hope that helps!
Best.
MAIN: MacPro 3GHz 8 core, 18G RAM, OS 10.6.8 DP 7.24, 2408 Mk III, 2408 mk II, MIDI Express XT, UAD-1, SLAVE: MacPro 3GHz 4 core, 10 G RAM. Libraries: VSL :SE/SE+, App Strings, Woodwinds, Sonic Implants Strings, EWQLSO (platinum) StormDrum II, Ministry of Rock, Motu MX 4, MACH V, NI Komplete 6, w/ plenty o' sample libs, Triton Rack, TX 81Z, Yamaha WX7, assorted woodwinds, drums, Yamaha P22 Piano
Thanks for the reply wrathy.
Are you at the latest version of both DP and VE Pro?
I use to have this problem, then I updated. Now it's ALLLL good
DP 8.04 64bit, VEP 5 (Latest), 1 Dual Quad 2.26 Mac Pro 2009 w/ 10.8 as DP DAW. 1 Dual Quad 2.26 Mac Pro 2009 w/ 10.6 as VEP Sample Machine. PCIe 424 - 4 2408's. Console - Yamaha 02R 96v2. AD/DA - Apogee Symphony IO. Waves, Sonnox, MOTU Plugins.
