hello
can anybody tell me why when i export scenes from BPM sound clearly bad as the original sound quality in BPM i mean the sound on BPM is fuller wich man can hear the stereo effect on it, just after the export sound very thin no stereo fx and so (
i tryed to push up the sample rate but no way allways the same result
do i make something wrong ? or its so !!?
"system Mac pro 2010, halo metric and REM sound cards"
BPM waves sound quality after exporting
Moderator: ssp
Re: BPM waves sound quality after exporting
I am having the same issue.... no resolution to it yet....
anyone?
I guess it's just you and me that's having this issue....
anyone?
Studio One Pro 1.6.5,iMac 27" i5 4G,OS 10.6.8, Presonus FireStudio Project I/O | DigiDesign Eleven Rack | DrumCore 3.0 | MOTU BPM 1.5
That's because (and I have no clue why they did this) BPM only exports to 16bit while it operates at 24bit. Seems to me we should have been given an option as to which way we wanted to export. Anyway, the workaround is to load BPM into a DAW and export using the DAW and not BPM.
World Class Major Label Quality Music Production - UrbanMultiTracks.com
http://www.urbanmultitracks.com/
Music Production, Mixing & Mastering - ChrismaProductions.com
http://www.chrismaproductions.com/
Easy enough.... seems there should be a prefrence setting for external importing from BPM..... Hopefully BPM supports my DAW... Studio One Pro from Presonus. I know DrumCore 3.0 doesn't support Studio One.
i don't see why exporting in 16bit is going to make it sound thin and lose the stereo?
this does not sound like the correct solution to the problem.
have you tested this yet?
OSX 10.6.4 / logic pro 9 / reason 5 / bias peak 6 / bpm 1.5 /
Loss of dynamic range due going from 24bit to 16 and maybe the dithering process algo is lacking. Just a guess.
