Axiom 25 pads and sample control
Moderators: James Steele, ssp
I'm trying to get the sample pads to play a sample when I hold it down, and stop the sample when I release. I used to do this on a hardware MPC, and can't figure it out in the virtual world. Help!
Re: Axiom 25 pads and sample control
You just need to switch from AHD to ADSR the amplitude envelope.Markansas wrote:I'm trying to get the sample pads to play a sample when I hold it down, and stop the sample when I release. I used to do this on a hardware MPC, and can't figure it out in the virtual world. Help!
Hope this help.
I'm look for the exact same thing Markansas.hugy wrote:You just need to switch from AHD to ADSR the amplitude envelope.Markansas wrote:I'm trying to get the sample pads to play a sample when I hold it down, and stop the sample when I release. I used to do this on a hardware MPC, and can't figure it out in the virtual world. Help!
Hope this help.
If BPM doesn't have this feature it is a BIG let down.
It should be a standard option if you want the pad to play the full sample as 'one-shot' (doesn't matter if you hold or touch the pad) or the sample to stop playing when you release the MIDI key/pad 'note-off'.
The ADSR is useless for me to achieve what I want without automating the release. unnecessary step I'd like to avoid.
Please let there be an option for this MOTU *crosses fingers*
As Hugy already pointed out, the ADSR envelope is the solution. Just set the release to 0 and pad playback will function as you desire.
If there is something else you are looking for please be a little more specific.
-GK
-GK
Just tried setting the release to 0 on ADSR, lot of clicking and popping, I have to leave it between 20ms - 60ms to kind of achieve what I want.grassrootking wrote:As Hugy already pointed out, the ADSR envelope is the solution. Just set the release to 0 and pad playback will function as you desire.
-GK
My issue now:
Is there any way to increase the length of the pad/note in the sequencer of BPM from 1/16 to 1/4 without changing the steps or resolution?
MOTU > Implement a 'GATE' function like in Logic's Ultrabeat in a future update, that will be excellent!!
Thanks GK
