It was out the very first morning that DP7 got out.timriley wrote:I can feel a DP8 wishlist coming on...
DP 8?
- Dwetmaster
Re: DP 8?
- timriley
Re: DP 8?
About time we had a DP9 wishlist then...Dwetmaster wrote:It was out the very first morning that DP7 got out.timriley wrote:I can feel a DP8 wishlist coming on...
Mac Pro Quad XEON/2.8Ghz/12GB RAM
Macbook Pro Core Duo/2.16Ghz/2GB RAM
OSX 10.6.8/DP7.22
OSX 10.6.8/DP7.22
- sdfalk
Re: DP 8?
OH MY GOD, I CAN"T WAIT UNTIL DP..zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
A Metric Halo ULN8-3D…mmmmmmm
DP 8?
Ah, THAT word again.Klaus wrote:...unusable...
Re: DP 8?
Klaus, I went back and read that thread. It seems that you are using Cuemix. Are you sure that the problem is with DP? It could be a Cuemix bug. Also, 2:1 sounds awfully suspicious. Could be a routing problem. I don't use Cuemix, so I can't verify, but I've had no problems of this nature with DP 7.James Steele wrote:Ah, THAT word again.Klaus wrote:...unusable...
Phil
Re: DP 8?
Who knows. I do know that if you have Cue Mix and DP open at the same time, and both have an input enabled, it will increase the volume coming in. One signal will come from CueMix and the other from DP and it will combine. I sometimes use this intentionally to get more gain when monitoring an incoming signal if I'm tracking to a mix that I have limiter/compressor affecting.
- Prime Mover
Re: DP 8?
It often introduces some phunky phasing phun. So if you want to get your phill of phantastic phasaliciousness, turn that phucker right on!
If not, either turn audio monitoring off in DP or mute CueMix.
— Eric Barker
Eel House
Eel House
Re: DP 8?
JamesJames Steele wrote:Ah, THAT word again.Klaus wrote:...unusable...
I meant this feature : Hardware input monitoring
is unusable, not DP...
Imagine, having setup a rec monitor mix, then recording, then playing back what was recorded, at completely different levels, as I said,
each track will be 2:1 louder, i.e. instead playing at -20 dB, it plays at -10dB, isn't this unusable ?
I would like to *not* use Cuemix FX when recording...
...and I think I noted that this bug shows regardless of using Cuemix FX or not, and I also noted that there is absolutely *no* double routing / monitoring via Cuemix FX going on.
This bug was confirmed here also
http://www.motunation.com/forum/viewtop ... 74#p376541" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
If someone with a 896mkIII could test and confirm this is not true, I'm open to learn and adjust my rig. Tests with other mkIII interfaces are welcome too, to narrow down...
and best to all
Klaus
- FutureLegends
Re: DP 8?
The problem here is that DP controls CueMix, sorta.
If you make the tracks not play (unclick the blue triangle, sorry I forget the right terminology) it works. But it's a drag having to turn them on again to listen to the take etc.
I've requested this too (having DP NOT control CueMix).
DPs control over CueMix seem to work fine only when all inputs have it's own corresponding output...
Another pet peeve is that DPs transport controls don't work when in CueMix and CueMix's talkback shortcut don't work when in DP...
Klaus wrote: I meant this feature : Hardware input monitoring
http://www.motunation.com/forum/viewtop ... 74#p376541" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
and best to all
Klaus
Re: DP 8?
Maybe so. I guess we have to deal with it until it's fixed. It sounds incovenient, as hassle, a PITA. "Unusable?" I dunno... YMMV.Klaus wrote:JamesJames Steele wrote:Ah, THAT word again.Klaus wrote:...unusable...
- cbergm7210
Re: DP 8?
I'm sorry...I thought this was funny as h@#$.Prime Mover wrote:It often introduces some phunky phasing phun. So if you want to get your phill of phantastic phasaliciousness, turn that phucker right on!
http://www.rfjmusic.com
- cbergm7210
Re: DP 8?
Frodo wrote:Or "phunny"?cbergm7210 wrote: I'm sorry...I thought this was funny as h@#$.
- Steve Steele
Re: DP 8?
I need DP8 to hurry up and bring it's 64-bit self out because my Waves WUP is about to expire. .. tapping nervously..
Mac Studio M1 Ultra, 128GBs Unified memory, 4TB SSD.
Interfaces: MOTU M2 and 8A (2.1 and 5.1 setups).
DAWs: Digital Performer 11, Logic Pro, Cubase 12 Pro, Studio One Pro.
Sample Libraries: Primary - VSL (all), Spitfire, (mostly all), and many others.
External Controllers: Metagrid Pro and Studio Logic SL|MIXFACE
Re: DP 8?
Just upgrade them on the Waves site, but don't install them. They'll create your Waves Cloud Account so they'll be ready when you need them. Your V8 stuff will still work off the iLok - you don't have to surrender a license or anything. Check with Waves if you have any questions.nightwatch wrote:I need DP8 to hurry up and bring it's 64-bit self out because my Waves WUP is about to expire. .. tapping nervously..
DP8.06 PT11.2.0 VEP 5.3.x
