Just MAS
Just MAS
I have a zillion AU and VST's but when i launch DP i only want to launch the MAS plugs.
I have had to re-install DP7. Before i make the first launch how do i just have the MOTU MAS plugs load up. In other words, I don't want to see the indexing of all my AU and VST plugs because this time around I only want to use the MOTU plugs.
Mac OS: Mojave
Re: Just MAS
Hi
You can use the Audio Unit Manager for removing AU.s temporary.
Download here:
http://download.cnet.com/Audio-Unit-Man ... 89957.html" onclick="window.open(this.href);return false;
jarok
Download here:
jarok
http://www.facebook.com/pages/Trio-Trout/140467307206" onclick="window.open(this.href);return false;
Re: Just MAS
Many thanks, iwill try it.
Enjoyed going thru your face book and playing some of the performance: you guys are gooooooood.
Mac OS: Mojave
Re: Just MAS
Audio Unit Manager is a great utility for this. However, if you want to handle everything manually, plugins can be found in:midiw wrote:I have a zillion AU and VST's but when i launch DP i only want to launch the MAS plugs.
~/Library/Audio/Plug-Ins
You'll see several folders there: Components (which are AU), VST, MAS, and so on. There are two Library folders. One is at the system level (usually your main hard drive), the other is under your user account. Be careful if you manipulate these manually though. Copy them, back them up, and be sure to put them back in the correct spot.
Just MAS
It might behoove you to just "tough it out" and let DP gather info on you AUs the first time. Then you can go into DPs prefs and set it so none of only some of the plugs will load in the future. That will save you from having to move AUs back into the Components folder when you use other apps.
- daniel.sneed
Re: Just MAS
AudioFinder has a very effective plugin manager.
Can save reports of your current plugins setup. This report can be saved within a DP project folder for future use, years later!
dAn Shakin' all over!
DP11.31, OS12.7.5, MacBookPro-i7-3.1Ghz-16GoRam-1ToSSD
Re: Just MAS
... and you can hit the "skip" button repeatedly until the examination window disappears...
Re: Just MAS
If you pull "MAS AudioUnit Support.bundle" out of the MAS plug-ins folder, DP won't load any AUs.
Re: Just MAS
Thanks, nice and easy solution.carrythebanner wrote:If you pull "MAS AudioUnit Support.bundle" out of the MAS plug-ins folder, DP won't load any AUs.
Mac OS: Mojave
Re: Just MAS
When you say you want only MAS plugins to load, do you mean only the ones that came with DP, or do you include third party MAS plugins, too?
If you only want the plugins that came with DP, press the option key while DP loads, then select Safe from the select plug-in set drop-down menu, and click OK. Then you'll get only the MAS plugins that ship with DP.
You can also create custom plugin sets, so if you want to include third-party MAS plugs, you can pull the MAS AudioUnit Support.bundle, then create a plugin set from the plugins that load, in Preferences, under Audio Plug-ins.
Good luck!
Good luck!
Mac Pro 8 core Nehalem,OS X 10.6.8, MOTU 896HD, DP 7.24, Finale 2009, MSI, Izotope Trash, Spectron, Ozone 4, Alloy, Rx2
Re: Just MAS
barreltone,
Thanks, another easy to do solution for me.
Actually not aware of that "option" trick: yep, hate reading manuals.
Mac OS: Mojave
