Whenever I click on BPM's presets, I get a message?,i installed the
UVI Workstation and copy and paste the BBA from a location onto the UVISoundBnks and i still get this message but from a user section on BPM i locatesd the UVISoundBank and load BBA from there and it worked
but when i turned BPM on again the file is missing .......can someone help
Moderator: ssp
Re: Whenever I click on BPM's presets, I get a message
If you have already copied BBA UFS from the BPM folder to the UVISoundBanks folder, you will then need to delete the BBA UFS from the BPM folder. Make sure the UFS is in the UVISoundBanks folder first. You can also drag the file there from the BPM folder in Windows to move it.
If you used an alias, make sure to delete the word "shortcut" from the file name so it reads exactly: Beat Box Anthology.ufs
bimz, you already had a thread started for this, and then you made another one which was not needed.
repeat threads will be removed without warning.
ok first what is your operating system xp, vista or win 7 this will help firstly, then i can give you the correct paths and the correct title names as i have them here from uvi:
Installing the Beat Box Anthology soundbank file
To install the Beat Box Anthology.ufs soundbank file, copy it
from the Beat Box Anthology DVD to the following location:
Mac OS X
startup disk/Library/Application Support/UVISoundBanks/Beat Box Anthology.ufs
Windows
startup disk:\Program Files\UVISoundBanks\Beat Box Anthology.ufs
Place the UFS files directly in this location, or create an alias
or shortcut to the file in this location, as described in the
“Installing the BPM soundbank files”
Mac OS X
Windows
Too many synths to mention!
Mac OS X
Windows
I DID JUST THAT WHAT YOU EXPLAIND ABOVE
AM USING WINDOW VISTA 64BITS,THE PROBLEM IS STILL THE SAME
Mac OS X
Windows
faithzone
ok well im using vista ultimate prem and my location for mine is the following:
C:\Program Files\UVISoundbanks\Beat Box Anthology.ufs
now as long as the file in there is the full file and not an original, copy this: Beat Box Anthology.ufs then rename your file by pasting into the name section. Then try it again and see if its ok.
It has to be that exact name, capitals and spaces as well.
on x64 Windows, the right program files is the x86 one if you are using the 32bits version of BPM.ssp wrote:ok well im using vista ultimate prem and my location for mine is the following:
Hope this helps.
Thanks a lot Hugy it worked,i copy the UVISoundBank from program files
into program files x86 and it worked. like you said am using the 32bits version of BPM, truely appreciate your help
faithzone
