velocity for sequence of rack part
Moderators: James Steele, ssp
davidb63
Post by davidb63 »
I see I can use the Graphs edit section for Banks, but this isn't avail. for rack sequences. Is there a way to edit velocity or other MIDI information for rack sequences?
b-righteous
Re: velocity for sequence of rack part
Post by b-righteous »
No!
Both step and piano roll sequencers are incomplete. You will find what is missing in one in the other.
davidb63
Post by davidb63 »
hmm.. I'm supprised you can't at least adjust velocity after you play a sequence. I always have a note or two that needs a little taming. I wonder if that's something they are looking at adding.
grassrootking
Post by grassrootking »
You can adjust the velocity by holding down shift while you click-drag vertically on the sequence notes. You will see the sequence notes get brighter or darker based on the velocity. This is the only visual feedback on velocity - no numerical values.
davidb63
Post by davidb63 »
Thanks, that does the trick. I'm about 1/2 through the manual, but I did poke around for that before posting... I promise! :shake: :rtfmmad:
b-righteous
Sorry, I had forgot about that one.
Still would be nice to have graph view for controller and vel tweaks with automation.
davidb63
Post by davidb63 »
No problem B! I still haven't found it in the manual.. I should be getting my 1.5 update tomorrow. Now i'm looking at all those uvi soundsbanks.. $hit, need to let me credit card cool down! lol.
