no samples in the browser, even after doing the alias thing?
Posted: Tue Jul 13, 2010 8:13 am
by itsthenoise
Can anyone suggest something to try?
I've lost the connection between BPM and it's samples in the browser [ load perfs works ok ], I've redone the alias thing but it still doesn't work?
[ mac's are rubbush nowadays, grumble, etc... ]
Re: no samples in the browser, even after doing the alias th
Posted: Fri Jul 16, 2010 5:36 pm
by b-righteous
On Windows here but make sure your alias is referencing the right location. If you moved or reinstalled then you want to delete the old alias and make a new one. You have to rename the alias so it is identical to the original ufs files. Remember there are two ufs files so you will need two aliases.
Posted: Sat Sep 11, 2010 4:14 am
by tiko
When you copy the aliases make sure you do them 1 at a time.I copied both at the same time and it did not work
Posted: Sat Sep 11, 2010 4:23 am
by itsthenoise
I found the solution in the end, had to delete all BPM samples and copy the original sounds from the install disk as clean copies.
still a mystery why it went wrong in the first place??
