Page 10 of 11
Re: My "Wouldn't it be nice..." list. (1st post updates)
Posted: Sat Jul 13, 2013 1:14 pm
by MIDI Life Crisis
It can. I think it has to be done as a mouse recording but those are pretty easy to create. I believe they can be both window and screen relative.
Posted: Sat Jul 13, 2013 1:17 pm
by amplidood
That's easy to do when menu positions are static, but the info bars are always morphing and moving around...
Posted: Sat Jul 13, 2013 2:17 pm
by Shooshie
amplidood wrote:That's easy to do when menu positions are static, but the info bars are always morphing and moving around...
You don't have to literally mouse it. You do it always in relation to a corner of a window that's always going to be open. In the Consolidated Windows, it's a little different. There's an offset. I forget what it involves, as I haven't made one of those in about 4 years, but you figure out where it's hitting, figure out the difference between the hit and the target, then incorporate that into the x,y coordinates. Then it'll hit the target every time. DP is reporting different window coordinates than the actual screen coordinates, because of the Consolidated Windows frame. It's solvable. I figured it out in about 20 minutes, then I had the offset coordinates for all time… but since I didn't use them again, I forgot even where I stored all of that. But it's doable. And when you really want a key, that's the way to go.
But isn't there a keyboard command in DP for that? It goes by another name, but it does the same thing. Am I remembering things that never were? (Honestly, I do that sometimes) I could have sworn…
Posted: Sun Jul 14, 2013 7:56 am
by amplidood
What might be a better solution is if clicking on a soundbite automatically made a selection ranged from its length. Right now it just highlights it.
Posted: Sun Jul 14, 2013 8:29 am
by bongo_x
I might be confused, isn’t this what happens when you double click with the selector tool? Same as in Pro Tools.
Posted: Sun Jul 14, 2013 1:37 pm
by amplidood
Indeed it does, bongo. Thanks for that. However, this works only in the Sequence Editor, not the Tracks Overview. I am always in Smart Tool mode, so I have to switch to the Range Selector to get this to work.
I think clicking a soundbite should always create a range selection for its length, or the length of several selected bites. Pro Tools works like this.
Posted: Sun Jul 14, 2013 2:51 pm
by FMiguelez
If you press ctrl-command-E, DP will display the selected Track's SBs in the GE with the correct zoom to show the longest selected one. I do this often and it works great!
I'm not near DP (
), so I can't confirm the shortcut, but I think it is like that.
Posted: Sun Jul 14, 2013 4:44 pm
by bongo_x
In Pro Tools double click with the selector selects the soundbite and sets the selection length, but triple click selects the whole track. I’d like to see that.
Posted: Sun Jul 14, 2013 5:37 pm
by Shooshie
In the DP preferences, go to Tools (I think), and you'll find the options for selection:
• Range Only
• Events Only
• Both Range and Events
If you want a range selection every time, choose Range Only… and so forth.
There are other ways to convert a selection to Range, but I won't go into that right now.
Posted: Mon Jul 15, 2013 8:49 am
by amplidood
These are all valid options. However, I've been in "All Selections" mode since it was available so many years ago. Having to switch tools just to choose events or ranges makes me feel like I'm in another app. The QuickKeys idea won't work, because the mini menu is a moving target within the window, not just on the screen. I still think the best solution would be either....
1. Give "Set to Selection Bounds" an assignable keystroke
or
2. Allow an option to have *event* selections automatically set to a *range* selection as well.
Posted: Mon Jul 15, 2013 9:19 am
by Dwetmaster
Double clicking an event with the "I" tool will make a time selection.
Posted: Mon Jul 15, 2013 9:22 am
by amplidood
Dwetmaster wrote:Double clicking an event with the "I" tool will make a time selection.
Only in the Sequence Editor... I still do a crazy amount of work in the Tracks Overview.
Posted: Mon Sep 02, 2013 11:08 am
by amplidood
Found a workaround for this problem. After clicking on a soundbite, I just "Move Selection Down" then move it right back up (shift-command down-up arrow on my system). It changes immediately to a range selection.
Posted: Mon Sep 02, 2013 10:15 pm
by Dan Worley
amplidood wrote:Found a workaround for this problem. After clicking on a soundbite, I just "Move Selection Down" then move it right back up (shift-command down-up arrow on my system). It changes immediately to a range selection.
That's my workaround, too. Shoosh actually turned me onto that about two years ago. In the SE I hold down the "I" key and double click the soundbite. I didn't know about that trick until last year.
I completely agree that "Set To Selection Bounds" needs to have an assignable key command. I've asked for this in the past. It just seems so odd that it doesn't have one. Glad to see someone else cares about it.
Posted: Tue Sep 03, 2013 2:29 pm
by Booter
There is a command called Set Memory to Selection. Isn't that what you're looking for?
