Hi,
Eachtime I load a combi (factory or user), I am not able to change any parameter (volume, EQ...). The knobs don't turn.It seems everything's blocked.
Have you also the same problem?
Is it normal or is there something I do wrong?
Thaks in advance for your help.
Steph.
Can't change any parameter in combi presets
Re: Can't change any parameter in combi presets
Electric Keys has two sound slots, and one of them will always be selected (the text is a little brighter). I've noticed sometimes after loading a combi, though, that neither part appears to be selected. Try clicking back and forth on the names of the two slots, then see if the knobs become active.
Hi,
Thank you very much for your answer.
You're right, when I click back and forth (even with a classic combi with one slot alone) some of the buttons now work.In fact all of them exept the EQ.
I can't turn these 3 buttons (Bass, middle, high). It's really strange.
I really don't understand.
Do you have the same problem?
Thanks in advance for you reply.
After clicking back and forth, I haven't seen any of the knobs continue to be nonfunctional. Which version of Electric Keys are you using, and which combis does that happen with?
Hi,
I use EK 1.02.
It happens with all the factory presets (not with the ones I create from scratch).
Thanks.
I use EK 1.02.
Thanks.
