Could someone please tell me how I could use MX4 and BPM together at the same time in the same Digital Performer project? Whenever I record enable MX4, all the MIDI data is instantly routed to MX4, even MIDI data that was intended for another plugin (like BPM). It also appears to be impossible to use multi-record with multiple plugins, as DP is only allowing my to record-enable one plugin track at a time.
Please Help!
Using MX4 and BPM Together in Digital Performer
Re: Using MX4 and BPM Together in Digital Performer
By default DP allows for only one record-enabled MIDI track at a time, and that one track will listen for incoming MIDI from all available sources. If you enable the "Multi Record" option (Studio menu), you can record-enable multiple MIDI tracks simultaneously and choose inputs independently for each track.
