Hi,
I am probably missing something here but I can't make FX on the Master channel work.
When I add one or severaly FX on the Master tab I cannot here the effects at all. However, if I add the same FX on the PAD itself I can clearly here the FX.
Any idea or feedback would be kindly appreciated.
/K
FX on Master channel not working in BPM
Moderator: ssp
Re: FX on Master channel not working
First, double-check that your master fader is assigned to the same output bundle as the tracks that you expect to hear through the master.
Then check if you have more than one master fader track (easy to do if you use V-Racks). If so, there's a priority order and only one of them will affect what you're hearing. See page 693 in the DP 6 manual.
Re: FX on Master channel not working in BPM
Hi,
thanks for your reply. I apologize for not being clear enough. I thought it was sufficient to post in the BPM forum. I am talking about Motu BPM not DP 6.
That is, my problem is within BPM.
/K
/K
Check that you don't have toggled the bypass on the master tab in the FX panel (the two circle on the tab should be black not grey)
HTH
HTH
Hah, no, you were clear enough — I just forgot which forum I was in ...kalbinsson wrote:Hi,
/K
Sorry for the delay, but HTH nailed it!
/K
/K
