Page 4 of 5
Re: James' Mixing Board mod 1.12 (links on 1st post)
Posted: Wed Sep 10, 2008 1:40 pm
by bOing
,,,AND ANOTHER THING!!!!...
Uh oh. Sorry, I was looking for Amplidood's thread.
Posted: Wed Sep 10, 2008 5:36 pm
by jlaudon
I was just wondering if anybody knows how to change the background color behind the solo/mute/rec/ words on the mixer (I've tried to make the lights more resemble the round ones in DP 5.13). When I look at the mixer, my eyes get drawn to the solo/mute/etc buttons as they seem the most 'busy' looking.
Thanks, modders! (BTW, couldn't find this answer in the manual
Posted: Wed Sep 10, 2008 8:10 pm
by James Steele
Don't know, but one thing I like about my latest mod is that in the graphic that has the scale from 0 - 127 next to the fader (MIDI Volume), I put a little note icon so you can distinguish MIDI tracks from audio tracks in the mixing board. I find this very helpful.
Posted: Thu Sep 11, 2008 2:00 pm
by thelonecynic
I thought that the triangle in the sends was there to indicate the signal flow?
Posted: Thu Sep 11, 2008 5:56 pm
by James Steele
thelonecynic wrote:I thought that the triangle in the sends was there to indicate the signal flow?
I thought it was there to indicate that there was a drop down menu. If it were signal flow, I really don't need it. I'm pretty acquainted right now with the idea that it flows from the top down. Also, if it were for signal flow, not sure what it's doing on the sends or the automation type boxes either.
Posted: Fri Sep 12, 2008 8:02 am
by tommymandel
Great idea about the little "note" icon near the Fader in the Mixer Window on MIDI tracks, James. Thanks!
Posted: Fri Sep 12, 2008 8:17 am
by amplidood
Just found this James...if you want the insert selection arrow to go away, just blank out the kPopupMenuPulldownIconSet_PictID.png file.
Posted: Fri Sep 12, 2008 6:22 pm
by bayswater
Can I select different pieces of James' mods and others? I like the simple approach to the changes in the mixer, but want to use different mixer caps. The downloads contain a Default_Style.xml file. Does it only work with the specific image files that are provided in the package, or can I use if with just some of the image files, and add some image files from other package?
Posted: Fri Sep 12, 2008 6:30 pm
by James Steele
bayswater wrote:Can I select different pieces of James' mods and others? I like the simple approach to the changes in the mixer, but want to use different mixer caps. The downloads contain a Default_Style.xml file. Does it only work with the specific image files that are provided in the package, or can I use if with just some of the image files, and add some image files from other package?
Which fader caps do you want to use? The original DP6 ones? To change the fader caps requires modifying one of the .png graphics inside DP6.
If you're talking about iPerformer's fader caps, I tried those but personally didn't care for them myself. The fader caps I am using are lighter in color and 2 pixels wider so they are very easy to see. Photorealism is nice, but sometimes it's hader to see. I'm striving for a situation where you can get an overall sense of fader levels by looking at the mixing board and not having to actually concentrate and focus to make out elements.
Posted: Fri Sep 12, 2008 6:36 pm
by bayswater
Frankly, I don't know where I got them now. It was from one of the various packages, and could be from a previous version of yours. I didn't like the squares caps, and preferred the rounded ones.
Posted: Fri Sep 12, 2008 6:38 pm
by James Steele
bayswater wrote:Frankly, I don't know where I got them now. It was from one of the various packages, and could be from a previous version of yours. I didn't like the squares caps, and preferred the rounded ones.
It might be the original DP6 caps then. Problem is I lightened them to be more visible and eliminated some of the bluish tinge. I may put a link up to an alternate version for people who like the rounded caps.
Posted: Thu Jan 01, 2009 7:12 pm
by James Steele
I uploaded a new version... 1.13. The only difference is I got rid of the black outlines around insert ovals, etc. It gives it a less cluttered, smoother look. I like it.
Link and screenshot on 1st post of this thread.
Posted: Tue Jan 06, 2009 8:59 pm
by monkey man
Thank you, James. FWIW, I appreciate the fact that you've kept both downloads' links in place.
Re: James' Mixing Board mod 1.13 (links on 1st post)
Posted: Sat Feb 07, 2009 4:20 pm
by BKK-OZ
Anybody try this in 6.02 yet?
Posted: Sat Feb 07, 2009 4:28 pm
by tommymandel
I've tried our 6.01 GUI mods in 6.02 with no problems.
