Hello all just wondering if i get a new 2408 MKIII will the PCI424 card fit and work in a G4 DP?
Thanks and talk soon TK.
PCIX424 backwards compatibilty?
From the MOTU site:
"If your computer uses standard PCI (5V) or PCI-X (3.3V) slots, our PCIX-424 card will be compatible with your system."
Last year I bought a new 2408mk3 which came with the PCIX-424 card. At first the card fit and worked just fine in my G4 MDD DP 1.25GHz - then recently I upgraded to a PCI-X G5, and the card works fine in the new computer as well.
You should be all set. Your only problem is: if you ever want to get a new-ish computer, that computer will have PCI-e slots and you'll have to upgrade the MOTU card to the PCIe-424.
