i got the 8 pre, i installed before connecting like instructed but then i followed the plug and play driver installs like i wasn't supposed to, whoops. so the drivers weren't installed correctly or somehting when i looked in device manager. then i just went into each drivers properties and uninstalled them.
couldn't figure out how to uninstall anything other than the drivers in device manager.
so now whenever try to run the MOTU firewire/usb installer ("installing MOTU FireWire/USB Audio Installer") it stops going right after its done installing the 5 MOTU drivers and just sits there with the progress bar at like 99%. it only goes away if i go in and end the msiexec.exe processes. If i end the "runhf.exe" or any other "__hf.exe" process this error pops up:
-There is a problem with this windows installer package. A program run as part of the setup did not finish as expected.
then it tells me the installer was interrupted bla bal, restart installer.
same thing every time. so i'm assuming theres just old stuff clogging the drain, so to say, whenever i try to re-install it.
help if you can, thanks
random info:
when i restart windows asks me to end process: extracting files (thought maybe i was just impatient and the installer was really working when i thought it wasn't but that's not the case cause it worked the first time is less time than i waited the past 99893 tries)
after i got through the install the first time i got to go into cuemix and motu audio setup and stuff.
