3 sentence ebay rant
- emulatorloo
"The only marks of wear are small scratches on the rack-mounting hardware where the screw was."
You mean to tell me that you could not afford 4 whole cents for nylon washers after you paid 1200.00 for your rack mount unit????????????????
Yes I admit it, I am a bit obsessive -- but I was trained by engineers who a) lay the rack flat on its back before mounting gear b) always used nylon washers
- Spikey Horse
- emulatorloo
Re: 3 sentence ebay rant
Suddenly I'm feeling that my normal level of obsessive/compulsive tendencies is inadequate. Now, I've got to get nylon washers for all the screws in my rack. On the other hand, how many of you have adjustable spacers that support every unit front and back while adding .25" breathing space between units? I designed my rack that way. But I just didn't think of nylon spacers! How stupid of me! How could I have allowed those screws to scratch my precious rack units???emulatorloo wrote:"The only marks of wear are small scratches on the rack-mounting hardware where the screw was."
- emulatorloo
I've seen pictures of your set-up -- yes you must get washers to complete it. I usually get the black screws and washers in a set, like this:Shooshie wrote:Suddenly I'm feeling that my normal level of obsessive/compulsive tendencies is inadequate. Now, I've got to get nylon washers for all the screws in my rack. On the other hand, how many of you have adjustable spacers that support every unit front and back while adding .25" breathing space between units? I designed my rack that way.
http://www.musiciansfriend.com/product/ ... sku=804687
Although certainly the white nylon ones from the hardware store will do.
Hey I like that .25 inch idea!
Shooshie, the most obsessive person I know about cut pieces of felt to put on top of each piece of rack gear to protect from the other pieces before he racked it. So you would get:
Piece of Felt
Korg Triton Rack
Piece of Felt
Yamaha A-5000
Piece of Felt
And so on.
He claimed this avoided rack rash on the top. I never asked him what he did about gear that was vented on the top, though.
- Spikey Horse
For gear in rack cases which will be moved about a lot (used for live etc) if the rack case is just a small plastic one with no spring mounting inside I wrap two strips of neoprene around them (approx 2inch wide, 1/2 inch thick). Lots of gaffa tape to join ends of the loops - it will stay on fine if there's a hint of a stretch... or maybe add a strip of tape accross from one neoprene strip to the other like an 'H'.
Using strips is easier than trying to make 'feet' and will protect whether placed on side or bottom. Can also be easily removed if needed without leaving marks on the rack case!
Just adds some protection against vans with bad suspension, being plonked down on the ground by heavy handed roadie etc etc.
Just thought I'd throw that out there!
I unmount all my gear weekly, and give the metal cases a coating of Turtle Wax, followed by a good buffing, a massage, and a martini. The power cord gets a coating of WD40 and irradiation treatments to ward off bad electrons. And I would install the gear in the rack with nothing less than velvet coated rubberized nylon washers.
recording: Mac Mini 2018 - 32GB RAM - 3.2 GHz 6-Core Intel Core i7 - two Focusrite Scarlett 18i20 - OS 12.7.4 - DP 11.23
mixing: MacPro7,1 - 256GB RAM - 2.7 GHz 24-Core Intel Xeon W - Focusrite Scarlett Solo - OS 12.7.4 - DP 11.23
Both computers: Kontakt Komplete 13 VIs and effects. Effects: FabFilter, Sonnox Oxford, SSL, PSP, UA, iZotope. VIs: Cherry Audio, AIR Tech, GForce, AAS, East-West, Garritan, Best Service, Kilohearts, Brainworx, UA
- mikebeckmotu
- emulatorloo
What about grounding? With all respect to those who are concerned the virginal quality inherent in new gear is lost when the equipment is subjected to metal-on-metal mounting, isn't low-noise performance the most important criteria? Sometimes insulating washers are a good thing. Sometimes they're not.
A little paint, or even an indelible magic marker, has amazing restorative powers. Almost as good as a crystal pyramid.
HC Markus
- emulatorloo
I met a girl with that once.emulatorloo wrote:... He claimed this avoided rack rash on the top...
Hang on; the vent's always down below, isn't it?emulatorloo wrote:... I never asked him what he did about gear that was vented on the top, though.
