Recording problem...help!!
I'm trying to print some tracks to audio in DP 4.6.
i have an incoming signal from a outboard synth (fantom XR) that is registering successfully on the audio monitor window, but not registering in the level meter in the track window or the mixing board. it's a stereo audio track (input via SPDIF from the traveler) and output assigned to analog 1-2.
i also have a monitoring aux track set up with the same input/output assignment that successfully registers in the level meters. i've tried routing that to the audio track to record via bus, and also turning off the aux track and recording directly in the audio via SPDIF (as i previously described).
What the heck am i doing wrong??
~Ryan
~Ryan
Re: Recording problem...help!!
You will not see the incoming signal in the mixer or track until it is recorded. You might see ACTIVITY in the track but if it is relatively sparse MIDI data you might not see it. Try recording and playing back. You should then see it in the mixer and track windows (assuming I understood you qeaution correctly).
You might have "Direct Hardware Playthrough" enabled.
Mixing board meters don't respond on input if it's set that way.
They'll work on playback though...
thanks, guys
that solved the monitoring signal problem...however, when i go to print the track, no signal gets recorded...thus no sound on playback......any more suggestions???
thanks for the help so far...we're almost there!!!!
I wish you could see input level on the fader VU, even in direct hardware playthrough mode.... The audio monitor is a hard to read, unnecessary window. Just had to vent that...sorry.
DP 4.6 Dual 2.5 G5 OSX.39 2.5GB RAM 2408mk3 with pci 424 and 1224. MTP AV Autotune 4, waves platinum 5.x NI B4, Mach 5, arturia minimoogV. API, calrec, UA2610, Distressors, adl1000....yaddayadda
in my last reply, by saying that so signal gets recorded, i mean that as i record, there is no waveform appearing, just a straight line, despite the fact that i can see a signal appearing on the level meter...aahhhhh...
so guys, i'm new to DP and MOTU
Check and see if auto record is activated. If so... it won't record/print till it reaches the punch-in spot.
G5 Dual 2G, 6 gigs RAM, DP 7.2, Mach V-2, OS-Leopard 10.5.8, Yamaha O1X control surface, EZ, Addictive Drms etc.
auto record is NOT enabled...any other guesses?
thanks though
thanks though
Are you seeing a good strong signal on the input monitor? If you see it and the track you are recording to is record enabled, you should see a waveform. Maybe send a few loud notes and see if you get anything at all? Also, you might want to check the AUDIO PATCH THRU settings. Can you hear the signal? Other than that and what has been suggested, I'm drawing a blank. The only flat lines I ever got was when there was no signal present (and during heart surgery...
<small>[ August 19, 2005, 03:35 PM: Message edited by: MIDI Life Crisis ]</small>
Have you got a voice for it .....
Look in the track if you have a voice setup for it ....
Aramis
Aramis
iMac 2012 27 ' 3.2 ghz 32 gigs ram OSX 10.9.4 DigitalPerformer 8.7 , MOTU Track 16, MOTU MachFive3.2, Ethno and BPM , Komplete 9, OmniSphere , Trilian and Stylus RMX , Axon mkII and Godin LG .
If there was no voice allocation the track could not be armed for record.Originally posted by Aramis:
Aramis
Studio Dog ,
You are right .....gosh !!!!!
I guess I was to in hurry to help .....
Aramis
Aramis
thanks for the attempt though!!
man, i've tried everything and nothing seems to work. i've made sure the sample rates match, clock is set to spdif. like i said, i can see the level meter registering (in both mix and audio monitor windows), but when i arm the track and hit record, it records.....but nothing actually gets recorded.
i know it's got to be something really dumb.
i know it's not the fantom because i've successfully done the same function with a different song in pro tools.
i just don't get it....can anyone else offer any advice?
One last thought... have you called tech support?
not yet, but i heard they're very difficult to get in touch with. and since it's saturday, and they're only open M-F...if i can't fix the problem by monday though, i'll definitely give them a ring.
thanks !
thanks !
