So, try the next solution cause for me it worked.
Everytime you load a song, i mean everytime!, go on settings (setup/configure audio system/configure studio settings) and deselect and select "plugin latency compensation" and deselect and select "pre-fill file buffer".
If you go on settings and you see that for example pre-fill was deselected is not a problem, select it, save, quit performer and reload the song, and after deselect and select the 2 fields (plugins compensation and pre-fill).
Now you can bounce.
I did 28-30 bounce in this way and all was perfect..
Remember, you don't need to do this operation before every Bounce, just after you load the song.
i hope this will work for you.
Cya
G5 2 ghz, 2.5 ram, DP 5.01, 828
