cpu performance?
- kelldammit
- Primary DAW OS: Windows
cpu performance?
just out of curiousity, how many simultaneous voices are you able to get out of MSI on your machine? i'm currently having some problems with cpu after loading 8 sounds...i guess i'm down to reducing the polyphony per voice...
Feed the children! Preferably to starving wild animals.
ASUS 2.5ghz i7 laptop, 32Gb RAM, win10 x64, RME Babyface, Akai MPK-61, Some Plugins, Guitars and Stuff, Lava Lamps.
Re: cpu performance?
Sounds like you are using MSI as a plugin in PPC application (DP 5 perhaps?). In this case MSI, altough it is UB app, runs on Rosetta and uses PPC code.kelldammit wrote:just out of curiousity, how many simultaneous voices are you able to get out of MSI on your machine? i'm currently having some problems with cpu after loading 8 sounds...i guess i'm down to reducing the polyphony per voice...
To solve this temporarily you can open MSI as a stand-alone application and route MIDI from DP to MSI. In this case you cannot record MSI audio output to Sequencer directly. Of course you can record your MSI audio to a file and then export autio in sequencer. RAX should do this trick, it is UB AU host.
Brrrrrrrrrr...
+372 56222285
