the new set sounbite gain is almost great.... so close to my fairlight it is tantalising....
just mixed a 30 min TV show with it - had an OMF from FCP along with QT DV file
would be better if it had a "trim" version - ie a key whereby you trimmed by an amount as opposed to now its set it to that amount
so if i entered 3 db it would make it 3 db louder
now I need to remember what the gain for the soundbite was set to before -
situation:
enter 3 on a bite- not loud enough - so have to enter 6
come back a few mins later and want to change it - still not quite loud enough - can't remember what I entered.. so have to start over again.. was it a 3 - oops thats quieter than before..
Then DP would really cut it in the post world....
( or at least allow the trim clip gain function to have a user adjustable increment 0.5 db are baby steps when it comes to mixing into compressor and limitor on a TV show with a deadline)
( yes this the same post as 5.1 feature upgrades but hoping that some one from MOTU will notice it here...)
and what's up with the no right click thing? ( it's been years now...._
imagine right clicking on the channel u working on and being able to choose the automation layer - way better than the little mouse trip to go and click on that pop up pull down thing way on the left....
clip gain function
isn't it just control shift up arrow/down arrow to move by .5 db?
audiovision style.
audiovision style.
http://www.ronmeza.com
Keystation 49e controller
Re: clip gain function
Fairlight style allows user adjustable clip level trim function as well as set clip gain function.
What is interesting is that fairlight allows a sort of clip based automation. You may fade between 2 diff soundbites... if the 2 soundbites are the same except at different levels then you get fade up or down...
the same is true of eq's too
I worked on an audio vision for a while and it's quite nice - I liked it's reverse 1 frame jog function - and it's clip based eq was very nice.
clip based level - fades and eq are great in the post world!
