Is it possible to set the sampling rate to 48 if you're using a powerbook without an external audio interface? Thanks for your responses.
eDrew
Sample Rates
Sample Rates
It's Not About Me
- kelldammit
- Primary DAW OS: Windows
- kelldammit
go to audio MIDI setup in applications/utilities. make sure that you're showing settings for the internal interface. in the lower left hand corner of that window, you'll see the input settings, and probably a pulldown option for sample rate. if 48k is there...then you can do it
kell
kell
Feed the children! Preferably to starving wild animals.
ASUS 2.5ghz i7 laptop, 32Gb RAM, win10 x64, RME Babyface, Akai MPK-61, Some Plugins, Guitars and Stuff, Lava Lamps.
